What's my boost limit with this combo?
So, those of you with more experience than me, chime in on where you'd put a hard limit with this combo: aluminum LH6 block, Summit ProLS pistons and rods, stock crank, AFR enforcer heads, BTR small bore LS9 style gaskets and ARP head studs. Turbo is a VSRacing Gen 2.5 78/75 with a billet wheel 1.25 A/R, 4" dump pipe.
I myself was thinking 22PSI, but maybe it could hit 25? I think the turbo will be out of steam at 25 lbs. Either way, can the short block handle it?
Fuel will be your limiting factor.
There're several guys on YB I follow running forged 5.3's on methanol running in the 30-40 lb. range and more.
Another gent routinely runs 30ish lbs. on E85 out of the barrel on a Gen IV SBE deal.
I intend on running around 22 psi on pump and meth with a rod/piston LS1 so with your fully forged deal, you'll be solid.
With decent flowing heads that turbo will be the limit. I doubt it will push 25lbs efficiently. Just depends how well the top end flows. Like you say, I bet that turbo is out of steam around 20-22psi. It will likely still pick up a little after that, but It won’t make 25-35+hp per pound it should.
Many times this is where people hurt things. As soon as the turbo stops making its usual gains per pound, its done. If you aren’t class limited, chasing more power after that isn’t wise. If you want more, get a more capable turbo. Only so much you can do with an under driven 75mm turbine wheel and a T4. I’d suggest T6 S400 line or similar. A legit T6 Borg S480 (even a cast unit) will make 1300 crank all day. Still the best all around bang for your buck 1000whp turbo out there IMO. It will also make more power per pound across the board. Often spooling better than the poorly designed 78/75 units. (depending on the 78/75 model). Happel picked up 100whp at like boost going from a 78/75 to a T6 S480. (believe it was a gen1 78/75)
So, keep your timing in check and add boost until it seems to run out as mentioned above.
Then, slowly add in timing to get the power you’re looking for while reading the plugs after every change.
But, I’m no expert.
Best to you!
We are always conservative with timing on turbo LS setups and run only pump e85. Don't get greedy with timing and always run as much octane as possible if pushing it. The turbo inlet should be getting the coldest air available as the intercooler can only do as much work as it can.... so don't grab hot underhood heated air as your source.
I always planned ahead for the goofy huge turbo. Going straight T6 is just more economical/practical IMO. Vband housings save a lot of room/weight as well and are pretty common these days.
I want to say it was a PTE turbo with an 80mm compressor and 96mm turbine in a T4 housing.
It was definitely smaller than a typical T6 turbo, Turbo Tech used them on their kits and the turbo was placed down low next to the engine on the passenger side so no way it was a T6.
Honestly, I'd leave it alone or maybe pony up for a PT 7675, those little bastards make a lot of power for what they are.
PT claims 1,450hp on their website so even if it only got you to 1,200hp you'd be able to hit your 1,000whp goal.
As for PT stating the 76/75 is a 1450hp turbo… That’s also massaged information. It won’t make 1450 on an LS. Though it might on a 2 liter engine. Precision and the like are some of the best units out there no question. But they are 2x the price and half as durable in my experience. Super sensitive to material being passed though the bearings etc. I’d run a pre-turbo filter if I invested in a precision. Personally, I think a quality S400 frame setup with the 87/96 exh wheel is a much better bang for your buck for a “1000whp” turbo. With a Borg (or s400 clone) I wouldn’t run smaller than the 87/96mm exh wheel with that goal on a v8.
The PT 8284 promod turbo is a bad little T4 if budget isn’t an issue. It will do an honest 1350 crank hp on a 5.3.
