any one seen this 900+ rwhp turbo camaro??
http://www.augsburg.edu/ppages/~chial/index.htm
No one around here has beeten the car, just wondering if any one know's or has heard of it? He did all the work himself, including the headers, downpipes. He just recently pulled several buslengths street racing on a civic that runs 11.20's @ at high 120's
I know him, and have seen his car run several times at the local street races. He doesnt give any rides in his car though. It sounds bad ***. He has a ford 9" and his frame is tied together very well. He coulnd't get the car to hook at the drag strip, as he was running on nitto's spinning all the way through 3rd gear. He still pulled off a 11.17 at 147mph I believe.
Originally Posted by smokinHawk
the dyno graph looks like it was done in paint
that is a very flat power curve, but can it be the way the torque drops off like that?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It looks like he let off about 6000 and for some reason the hp just flatlined - never worked a superflow chassis dyno so I have no idea what happened there.
He just dyno'd 1003 rwhp on around 23 pounds of boost. The run where he ran an 11.47 at 137, not 147 was on only 6 pounds of boost. He could not turn the boost up higher, because he was roasting his nitto's. He recently pulled on a Busa w/ nitrous from a 50 punch. He has not yet set up his suspension properly to launch. He bought his turbos from the guy in the grand national w/ the 2 turbo's sticking through the hood that dyno'd an insane amount of power.
