Truck manifold gaskets & flanges? (cat side)
Anyone happen to know if anyone sells gaskets and flanges for the cat con side of the exhaust system? I can cut my own, but if there are GM part numbers for them, or if someone already sells some laser cut flanges that'd be an awesome time saver.
Or know some keywords I can use to find the part #s I'd need
Thanks
Andrew
Everything else has a habit of blowing out
Basically the hight temp RTV will fill the imperfections in the mating surfaces
works like a charm for me
Also make sure you use the silver anti sieze on all the hot parts if you wanna ever get anything apart after
Kurt
Also, do you run RTV like the post above you suggests?
Thanks
We also use the Hi-temp rtv on the three bolt flange.
Kurt
Thanks
at least 98's and 99's are the 2000-2002's that way also?
SC-
