TTi kit questions
Old Sep 22, 2004 | 04:25 AM
frey51's Avatar
Default TTi kit questions
Alright. I am trying to decide where to take my car in the mod department. I am 98% sure I am going with the TTi kit. But I need a little feedback from you guys that have the kit, or you turbo gurus. First off, my car is pretty much stock, and will stay that way even after the addition of the turbo kit. Basically what I mean is the turbo kit, asp pulley, a tune, and a rear end after a while...these will be all the mods, and that would be for a few years until I have a better cash flow. How will the kit perform on a completely stock engine. Should I add a larger headgasket to lower my compression? Also should I toss in a comp918 kit somewhere along the way to strengthen my valvetrain? I dont have much money, and it will pretty much be a budget build. Plus once it is running I want to keep it running. Please gimme a little insight.
Thanks
Fry
Old Sep 22, 2004 | 04:48 AM
smokinHawk's Avatar
going FI is never cheap.
first off what will be your imeadiate power goals?
where you thinking of going witht the T61 or T76?
lowering your CR will help, you can turn up the boost alittle farther.
main thing to prep your motor if you want to keep it stock. Id get some 6.0L heads, valvesprings. Its very imortant you upgrade your fuel to, so get injectors and a walbro intank pump.
those should keep your car running better and less chance of something going wrong.
Old Sep 22, 2004 | 05:22 PM
frey51's Avatar
Well I will be going with the T61 setup and the kit comes with a fuel pump, and I am going to get 38lb svo's. My power goals are basically in the 400+hp range. I dont really have specific goals, just to increase my power, tq, and performance. If I lower my compression with a bigger headgasket, and add a 918 kit will that be suficent enough to handle the power without breaking? Eventually I will add the 6.0 heads, but that wont be for a while.
Thanks
Fry
Old Sep 22, 2004 | 06:11 PM
frey51's Avatar
Basically what I really need to know is will a stock ls1 handle this kit while I slowly build upon the turbo platform. I probalby wont go with a built block until way down the road.
Fry
Old Sep 22, 2004 | 07:28 PM
dynedta's Avatar
chronic masturbator
yes it can handle it but tuning is key
Old Sep 22, 2004 | 08:43 PM
frey51's Avatar
I have a tuner that can do the tuning for me. (Jason at fbodycentral.com) They are the closest shop to me that has Edit, and I have talked with him about his FI tuning abilities. He has done several turbo cars, and is pretty reputable with ls1edit which is the tune I am going with.
Thanks
Fry
Old Sep 22, 2004 | 08:47 PM
mi021le's Avatar
and grannys up here also.
Old Sep 22, 2004 | 10:05 PM
frey51's Avatar
??? ya lost me.
Old Sep 23, 2004 | 03:35 AM
KissMySSo1's Avatar
I have nothing but problems so far with mine the car breaks up after 4200rpm and only made 380 rwhp at 8 PSI with the T76 kit. I don't really regret buying the kit yet because i know the car will be sick when it's right. When i do regret it is when you see it for sale. Theres only a number of things it could be i'll keep you posted on how it turns out.
Old Sep 23, 2004 | 05:12 AM
smokinHawk's Avatar
translation: he is about to get the bisznit done at fbodycentral as well.
they get that thing in yet?
Old Sep 23, 2004 | 02:31 PM
mi021le's Avatar
man yesterday. cant wait till i get it back. but i dont know when still waiting on QMP? its been a month and no fuel pump or alc. been calling all week no answer. so do know when all will be done.
granny was the computer wiz at fbc then he left. so hes also very good. hes on efa. names granyshifting, shoot him a pm. i might wen i get my car back for more tuning.
Old Sep 23, 2004 | 04:20 PM
smokinHawk's Avatar
id you want my hptuners file as a starting piont
9.0:1 CR, 224/224-114 cam, 42lb svo injectors.
if your cam, CR, injectors are close it might work till you get a tune.
