Slowly but Surely
Old Nov 13, 2004 | 10:40 PM
FSTR-THANU's Avatar
Outlaw 10.5 Director
Default Slowly but Surely
My time line for building this new turbo combo is OFF a bit but thanks to Nick D. the block is fully deburred and bathed. All of the bore/main measurements are documented and the main bearings have been fitted. Big Jelly pin fit the pistons/rods and Tim and I washed and prepped them for assembly. I should have a short block tomorrow afternoon! I will post more details then but here are a few pics from today anyways.
The GRP Aluminum Rods and Diamond Pistons are all coated by Dart Coating's. These piston's and rod's really are work's of art!
Old Nov 13, 2004 | 11:45 PM
427's Avatar
427
Looking good!!
Looks like somebody got a new rod hone!
Kurt
Old Nov 14, 2004 | 01:06 AM
granitemonkey's Avatar
Awesome looking
Old Nov 14, 2004 | 02:37 AM
BIGBOS's Avatar
Can't wait to see that thing get together
Old Nov 14, 2004 | 06:44 AM
NA$TY-TA's Avatar
Tom,
??.MM Housing and a 88MM wheel on the turbo your going with?? You still going to run a TH-400 or you going to run a glide now?
Kyle
Old Nov 14, 2004 | 11:20 AM
FSTR-THANU's Avatar
Originally Posted by NA$TY-TA
Tom,
Kyle
It is an 88/98. I am still going to run the 400 but there are plans to change that and not to a glide.
Thanks!
Tom
Old Nov 14, 2004 | 03:19 PM
NA$TY-TA's Avatar
Jerico, Liberty?????? Air assist.??
Shes going to be one bad mother.... whats teh Cubes?? Stock ci???
Kyle
Old Nov 14, 2004 | 04:30 PM
Stenod's Avatar
LS1TECH Sponsor
What kind of heads are you running?? those valve realiefs look kind of funny
Stenod
Old Nov 14, 2004 | 04:33 PM
FSTR-THANU's Avatar
Stenod
AFR's
Tom
Stenod's Avatar
LS1TECH Sponsor
Sweet!
Old Nov 14, 2004 | 05:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
88/98, so the 'drag radial' turbo as it's called? That's what a few others are running.
Old Nov 14, 2004 | 07:34 PM
TwnTrboCE's Avatar
I believe he has the same turbo as us.
Good to see some progress being made. Next season is going to be a lot of fun.
Old Nov 15, 2004 | 08:34 AM
Reckless's Avatar
Super Moderator
Why flat tops? Only looks like about -4cc reliefs, what about cr? Looking forward to seeing another fast turbo car in Atlanta come April
Old Nov 15, 2004 | 10:43 AM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Todd, look's can be deceiving!! The pistons are not flat tops, they are dished. Just not your traditional dish. Also the valve pockets are deeper than -4cc
Old Nov 15, 2004 | 02:07 PM
FSTR-THANU's Avatar
Do you mean 10.5:1 is not a good comp ratio for a boosted motor?
Tom
Old Nov 15, 2004 | 02:40 PM
LS1Tech Co-Founder
Chris You Look Hot U Been Working Sexay????
Old Nov 15, 2004 | 02:57 PM
John, I am not your type!! BTW, did you get the PM I sent you?? I take it your just ignoring it, right?
Thanks
Old Nov 15, 2004 | 06:05 PM
427's Avatar
427
I think it should be higher!!!!
Kurt
Tom
Old Nov 15, 2004 | 06:08 PM
LS1Tech Co-Founder
PM sent back. Parts look good, when will the car be fired up? You have manifolds yet?
Old Nov 15, 2004 | 06:22 PM
mustangcobratim's Avatar
I agree with Kurt. isn't around 13.5:1 about right?
Tim
