STS turbos 60-1 vs GT67
I am very interested in this kit and was wondering as far as the 2 diff turbos if anyone had some dyno sheets to compare the 2. Also if anyone can clear up some questions about spool time vs the two. Right now i have a stock bottom how much hp can the 60-1 go up to, where does it fall off? I will get a forged bottom but not for awhile should i just opt for the gt67 now or wait and upgrade. I would also have a fmic for them to push through if that matters as far as cfms they have to push. Thanks
12 Second Truck Club
Most of the dyno sheets I have seen for the 60-1 fall off around 5.5K but the spool time is insane.
If you want big HP then I'd go the GT67 in a heartbeat. If you just want awesome spool and great street manners the 60-1 is cool.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If you want big HP then I'd go the GT67 in a heartbeat. If you just want awesome spool and great street manners the 60-1 is cool.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I went with a 60-1, popped by motor, and now want a GT67. Get the bigger turbo now, so you can have more boost when you pop yours, too.
I will say that with the 60-1, my LS1 drives like a stocker until I hang a foot in it, then it gets a little crazy. I hear that the 67 hits quite a bit harder. At 12 psi though, the 60-1 hits hard and I'm out of turbo now.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Tenured Member
60-1 is fine for a stock motor.
check out
https://ls1tech.com/forums/forced-induction/264169-jlturbo-sts-dyno.html
check out
