Jim Filipowski's 1993 Camaro Setup?
LS1Tech Co-Founder
I was wondering if anyone was familiar with his setup and could describe how it works? I've read it's a 360ci SBC with a blow-thru carbureted turbo setup.
I believe his best is 8.teens.
His site is here:
http://www.jim-powski.com
I recall Guido posting up some pics a while ago.
I'm wondering:
-what size carb?
-what size turbo?
-glide?
-gearing?
-tire size?
His site is here:
I'm wondering:
-what size carb?
-what size turbo?
-glide?
-gearing?
-tire size?
Steve Morris of Morris Racing Engines in Muskegon, MI has a combination he just built that if I'm not mistaken is 540ci BBC Blow Thru setup that made 1689hp on pump gas blowing thru a carb via ATI Blower. Here is his link to call him John he is a really nice guy and has alot of experience with blow thru setups like above referenced.
www.stevemorrisracingengines.com
You are probably better off getting in touch with them. From what I understand the carbs need a few things done to them to get them to work good in those applications. Probably much more important at their power levels. Here is another web-forum you might be able to get some info from too... http://www.boards2go.com/boards/boar...ser=huntracers
SSU Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
i saw in another car where they used a 4150 950cfm carb + a rising rate fuel regulator?
