is it safe??
Old Apr 15, 2005 | 09:13 PM
hpjunky98's Avatar
Default is it safe??
is it safe to run an ati procharger on a 98 ls1 with 130,000+ miles on it? the motor has been well maintained and is in what i belive to be good condition. what can i do to check? thanks for any and all help!
Old Apr 15, 2005 | 09:33 PM
hpjunky98's Avatar
ttt......
Old Apr 15, 2005 | 09:38 PM
DarkblueTA's Avatar
you can do a compression check and a leakdown test.
If both tests come out well, then get one. I have a P1SC on my car and its got 122K miles on it.
FYI, it might be for sale soon.
Old Apr 15, 2005 | 09:59 PM
MelloYellow's Avatar
Leak it down 1st and you should be ok if the rings are.
Old Apr 15, 2005 | 10:06 PM
hpjunky98's Avatar
i'm planning on replacing the oil pump, but is their any other weekpoint i need to adress before i consider FI? oh btw my car is in cali, so everything needs to be cali leagal.
Old Apr 16, 2005 | 03:41 PM
DarkblueTA's Avatar
If its a 6 speed....clutch then a rearend(12 bolt or 9"). I would put a 160 thermostat in the car too. I never had an overheating problem and I was in Texas and Las Vegas. Just make sure you use good oil(I was using Mobil 1 15w40) and keep your other fluids looking good/topped off. You should be fine.
Remember, don't go crazy on the boost on a stock engine either.
Old Apr 17, 2005 | 04:20 PM
hpjunky98's Avatar
what boost should i run if i get the procharger. oh and i'm getting a 9 inch with detroit locker and 4.11s soon hopefully and the clutch....well what would you recomend? i just spent around a grand for the stock clutch to be replaced...
Old Apr 17, 2005 | 06:07 PM
DarkblueTA's Avatar
I was using stage 3 Specs...but for the turbo kit, I went stage 4i. Ask around and see what everyone else is using.
