cooling ?
Old Jun 14, 2005 | 08:11 PM
moto-mafia's Avatar
Default cooling ?
Hey installed a procharger on a 99 trans am , couple months ago , everything has been fine, until recantly i used the ac for the firt time and the car ran hot???? any ideas ??? can someone also send me the CORRECT wiring diagram for the procharger fan ??? thanks
Old Jun 14, 2005 | 08:48 PM
moto-mafia's Avatar
tttttt Anyone
Old Jun 14, 2005 | 09:51 PM
NoGo's Avatar
Just turn your car on, wait for the fan to turn on. Put your hand in front of the radiator. If the fan is pushing towards the front of the car flip the wires to that fan, it will reverse it's direction.
The old ATI fan setup didn't work so well in warmer temps on some cars. Alot of folk did some custom work or went with Be Cool fans.
I run a custom fan setup to keep mine cool.
Old Jun 15, 2005 | 07:31 AM
moto-mafia's Avatar
TTTTT anyone else have any ideas" ?
Old Jun 15, 2005 | 07:54 AM
BOONE's Avatar
Default cooling
I went with griffin and spal, you probably will need to upgrade.
Old Jun 15, 2005 | 03:33 PM
moto-mafia's Avatar
TTTT where do i get a fan setup and how much are they?
Old Jun 16, 2005 | 02:08 PM
BOONE's Avatar
Default duel spal pushers
Hey moto, i did a search and SSoramac has duel spal pushers on his, i think pushing through his ac condenser. Id pm him about price, part # and clearance tech. There are probably others. My single was like 120.00. They are somewhere over 200.00 i think?? I put foam tubing from ace hardware around my shroud edge, just got some too large and wedged it in, you might consider this around the edge of the shroud, and between the edge of the condenser and rad, to minimize volume loss. Some clear silicone will help hold it, it only takes spaced single drops, and you can hardly see it.
Old Jun 16, 2005 | 02:25 PM
99SS-T's Avatar
I use a flex-a-lite fan. It is a twin 12" unit. Cost me 236.00 from summit. Part # FLX210. It blows REAL hard and it is a real slim unit. Cant be more then 2" thick. You can definatly fit it on the backside of hte ac radiator and have clearance. It has teh gasket goin around it so it seals real well. I believe it came with a thermostat also. It is a real nivce setup. GL man
John
Old Jun 28, 2005 | 02:55 PM
Vette Mag's Avatar
John
Is this setup a direct fit for a ProCharger-equipped car (i.e., as a replacement for the single ProCharger fan), or does it require modification and/or fabrication? I'd like a little more cooling capacity, but I don't want to hack up the car if I can avoid it.
