Threaded IAT sensor Part # or application??
Old Jun 21, 2005 | 08:05 PM
camarogod98's Avatar
Default Threaded IAT sensor Part # or application??
Does anybody know what gm vehicle uses the Threaded IAT sensor that will work with our cars. Like ATI uses. I need an application so i can get one at the parts store.
Old Jun 21, 2005 | 10:44 PM
KraZy's Avatar
TTT
I would like to know also
Old Jun 21, 2005 | 11:04 PM
Blackbird's Avatar
i believe they actually just take a die to it and make threads. or whatever the thing you make threads with is called.
Old Jun 21, 2005 | 11:21 PM
y2khawk's Avatar
Old Jun 22, 2005 | 07:29 AM
KraZy's Avatar
Thanks!
Old Jun 22, 2005 | 07:42 AM
Wet 1's Avatar
Where are you going to thread it into?
Old Jun 22, 2005 | 10:12 AM
Blackbird's Avatar
oh cool. didn't know there was one already made that way. nice.
Old Jun 22, 2005 | 10:30 AM
SUPER DAVES Z's Avatar
http://www.rs-autosport.com/
Scroll down about half way, they're around $21.
Old Jun 22, 2005 | 09:10 PM
Ok guys I have figured it out thanks to Y2Khawk.
Go to your local parts store and buy a IAT sensor for a 1989 Chevy Berreta 2.0L
Its that same as our stock ones except for the fact it has 3/8" pipe threads.
I bought one at autozone for 25 bucks.....got home and fired up My Mastercam CAD/CAM program and designed the bung for it then i loaded it into the cnc mill and cut it out. I made the outside of my bung 13/16" hex and tig welded it onto my aluminum elbow that goes right before TB.
Once i get it all polished i will post pics. My MAF is a one of 3D machined billet custom that has a reworked knife blade for better flow.It took over 8 hours on the mill to 3D the knife blade inside the bore! I stripped the anodizing off my tial BOV and anodized it to match my MAF.
Old Jun 22, 2005 | 09:31 PM
HellRaiser's Avatar
This something I was wondering about. Is it alright to use the stock one with the rubber gromment? Has anyone ran it that way without any problems?
Old Jun 23, 2005 | 12:23 AM
frcefed98's Avatar
Me on my PD set up(6psi), ATI FMIC set up(15-16psi) and now the turbo set up(12psi until I get this oil issue solved)
No problems with the stocker and grommet. On my ATI set up I epoxied the IAT sensor and grommet to the TB elbow....but it was overkill.
Old Jun 23, 2005 | 04:47 AM
HellRaiser's Avatar
Sounds like it will work then if you ran 15-16psi on your ATI. The real test will come when you get you oil issue fixed and get a WOT blast.
