Why Can't We Burn Methanol in Small Amounts?
- Dug
That could be one reason. There are probably others.
J.
Second, the A/F for Methanol and it's mixes is different.
Stoich on pure is in the 5:1 range, and stoich on the M85 is in the 7.5:1 range.
That means first, you need to change the PCM to deal w/ the different stoich ratio. Second you need at least 2x the injector you have now to use M85 and still make the power your at now. That also drives a pump that can flow the required mass.
Also, the thermal energy in the fuel is less. You will make less power w/ the methanol than w/ regular gas. I don't completely understand that, but i'm not a chemical engineer after all <img src="gr_images/icons/wink.gif" border="0">
Methanol is nice, it's a high octane number fuel, has it's own built in cooling properties. But it's not as simple as pouring it in the tank.
The additive can get away w/ it becuase it's a small ratio. Remember the PCM can go +/- 25%.
An interesting exercise is to run a tank of pure gasoline and watch you l-trims. then run a tank of the oxygenated fuel, ie 10% ethanol. I bet you l-trims come up a noticable amount. Since the stoich ratio of the gas-o-hol is a lower ratio the PCM compensates.
Ask me how i know..... <img src="gr_stretch.gif" border="0">
I designed/built/programmed/cal's the ECM in the Cornell FSAE car in 98 and 99. Turbocharged 600cc Yamaha FRZ running M85 <img src="gr_grin.gif" border="0">
You can run alcohol in small mixtures.
formula #4 <img src="gr_stretch.gif" border="0">
http://www.gnttype.org/techarea/misc/octanebooster.html
[ January 22, 2002: Message edited by: y2khawk ]</p>
I have used the torco acclerator stuff. It's a strong MMT based blend. One look at your plugs will tell you that after using it.
Torco also sells Methanol and they say it's 99.5% pure but that is unrelated to their octane booster!
Steve, that was a wild guess as they don't say anything about what it's made of. I had a hard time getting anyone to say anything about the Torco stuff except for one person. So you've used it, do you think it's better than running race gas? It's certainly cheaper!
- Dug
<img src="gr_tounge.gif" border="0">
I can't remember the exact ratio of methanol that was blended but I know we cracked the gas that was intended to be 87 octane at 83 octane so the methanol that was added was done so to raise the octane rating 4 points. We blended the 94 octane gas at 91, so the methanol added there brought it up 3 points.
Methanol is safe for newer cars fuel systems since many manufacturers are making cars that are capable of running straight methanol fuel (they are the ones with the little green leaf on the back of the car).
One item to keep in mind is methanol will pick up water and transport it very easily. In gasoline, once the water content hits approx 900 ppms, it begins to bomb out of solution, but in methanol, the ratio is much closer to 1% (10,000 ppm). This is where you can run into serious problems as this will drop the octane rating dramtically.
We combated this issue by not mixing the methanol till it was delivered to the stations. This way we were able to keep a drying agent in the storage tanks of methanol to assure as little water absorbtion as possible.
That's all... <img src="gr_stretch.gif" border="0">
Dennis <img src="gr_grin.gif" border="0">
My best advice, make sure you keep a dry fuel system if you start to play around with any kind of octane booster as they all are very hydroskopic.
- Dug
Not getting into the specific chemicals, they claimed they actually have all the elements in their Accelerator product that comprises hi-octane racing fuel, and concentrate it.
He was convincing enough for me to blow my first $60+ bucks or so on a case, and when I tried it... it worked. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
What more can you ask? <img src="gr_stretch.gif" border="0"> Well... I could ask for no coloration of the plugs and to get the product free, but that won't happen. <img src="gr_images/icons/wink.gif" border="0">
