Upgrading to Vortech T-trim
the owner himself is running a YSI with the same bracket.
Just call and tell mark/mike to make the modification to the bracket if they already havent shipped it
They are actually closed until next Monday, so I know the order has not gone through yet.
Thanks a bunch! I hope don't crack the block!
I may take the car to the track this Friday to see if I can get another tenth or two out the G-trim. When we dynoed it last week, it picked up another 40hp with my new camshaft, but I lost 2PSI of boost.
In that case is it worth going all the way up to the YSI, or just stick to the current plan with the T-trim.
By the way, do you have a website or something with more details on your setup with pictures?
T-Trim will easily go in the 9's.
My blower would go high 9's on pump gas at probably low boost.
A bonus with the YSi is it'll take less boost to make the same power. The aftercooler isn't rated to handle the amount of cfms the bigger blowers have.
crunch if you can pm the specs on your motor i'd like to compare it to my combo. looks like judging by your mph that you are making approx 550ish to the wheel
http://psj.ls1tech.com/gallery/main....=464&g2_page=4
