Iron block VS Alum
Old Jan 23, 2003 | 01:13 PM
ls1formula99's Avatar
Default Re: Iron block VS Alum
Well I was down at the PRI HP show down in Indiana a few months ago and was speaking to the people at the lingenfelter booth and was told by them that the Iron is not much stronger at all for the weight gain, they said resleeving or CR5 block are your only alt. for much stronge block. Im shooting for 650-700 rwhp but dont want to sleeve and dont have the $$ for he CR5, so I assume I should just stay with my alum. and build it strong?
Old Jan 23, 2003 | 01:30 PM
Blkknight's Avatar
The iron block is cheaper and you get a free larger bore <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . With the stock crank it is a 366, 4" stroke 370 or so, 4.125" 402. I'm going with the iron block for a couple reasons. I'm paranoid and you get a larger bore. I'll make up the weight with some lightweight front end stuff.
If your on a budget and you want the extra cubes and don't mind the weight difference then take the iron block. The aluminum block has shown it can take the power though.
Adam J
Old Jan 23, 2003 | 01:36 PM
Can someone tell me what is involved with going to the iron block in an Fbody?motor mounts,oilpan etc.Thanks
Old Jan 23, 2003 | 02:09 PM
Blkknight's Avatar
Everythings the same. You just have to drill a hole for one of the external components. Can't remember what off the top my head though. If you do a search in the internal engine section you should find it.
Old Jan 23, 2003 | 02:23 PM
Black LS1 T/A's Avatar
Moderator
A boss for the alternator bracket is not drilled. That's the only mod I had to do to the block. Also, I relocated the ground strap on the passenger side. No big deal.
Call Golden West Performance (303-346-5232) to get your questions answered about the iron block vs alum block.
I guess if you can get the horsepower you want without too much overbore or stroke, you'd be ok. I wanted more cubes though. I put down as much RWTQ as some of the turbo's at on 7 PSI.
If you want to bring torque up to match your new horsepower, you've gotta have more cubes.
Old Jan 23, 2003 | 02:24 PM
Danny's Avatar
75lbs????? Yeah right! Try 120lbs+ The iron block is heavy. Of course you can always lighten the frontend up. But i'm still going w/ me set up. Check it out....
01 LS1 block
375cid
9:1 CR
6.0L racing heads
Holley manifold
80mm TB
All forged internals
Oh and did i forget TWIN TURBOS @ 10-13PSI BABY!!!!!!
600RWHP+ here i come....... <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Jan 23, 2003 | 03:21 PM
Yeah that setup looks sweet, makes me think maybe I should ditch the s/c and 408 stroker idea and get a turbo and do a setup like that? Im looking for a torque monster, hmmm what setup to go with??? Any thoughts.
Old Jan 23, 2003 | 03:26 PM
VINCE's Avatar
Shorty Director
How are you getting 375ci out of 346ci?
Old Jan 23, 2003 | 06:45 PM
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Danny:
<strong> 75lbs????? Yeah right! Try 120lbs+ </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where do you get that figure from? Everyone I've talked to says 70 or 75 lbs heavier.
Old Jan 23, 2003 | 08:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I just sold my iron block, it's 75-80 lbs heavier shall we bet? I have the shipping weight on the bare blocks to compare... from valvegod.
Old Jan 23, 2003 | 09:07 PM
xtream1's Avatar
FWIW, just had a new bare LS6 block shipped to me. UPS weight tag-132lbs in cardboard box with wood crate frame holding block. No heads, internals, or accessories.
Old Jan 24, 2003 | 12:07 AM
Default Iron block VS Alum
Hi, was planning on building a stroker for boost, what would be stronger? Would think the iron but was told that it is not much stronger and for the weight it would not be worth it??? Any info on the pros and cons would be great. Thanks Ryan
Old Jan 24, 2003 | 12:13 AM
LS1Tech Co-Founder
I think iron is significantly stronger, and has a more rigid deck surface. Downside is you add 75 lbs to the nose.
Old Jan 24, 2003 | 12:58 AM
Moderator
I was told by builders I talked to that unless you can afford something like the C5R block, the aluminum block is not strong enough to hold a lot of horsepower. It was recommended to me that if you were building the LS1 for RWHP in excess of 600 RWHP, you should consider a stouter block.
I don't know if the extra 70 pounds makes that much more difference (I know it seems it would, since guys go so far as to move their battery to the trunk and such). But you could spring for the ligher K-member (BMR?), which would lighten it back up.
I guess you have to weigh (no pun intended) the extra power you could safely extract from the iron block compared to what the aluminum block could safely produce.
I weight 190 lbs. I saw a guy racing one day that had to weigh between 250 and 300 lbs. What you gonna do? <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Also, I don't know what affect just 70 more lbs. has on the reate of acceleration down to the end of the track. I suppose the only way to know is for someone to put a 70 lb somewhere under the hood and try it with the same power, same car.
Too many factors have changed for me to really compare. I guess if I never anticipate going above 600 RWHP, I would stay Alum. When I can afford to get my fueling right where I can boost it more <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> , I hope to get close to 700 RWHP.But that's about 175 RWHP away righ now. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Jan 24, 2003 | 05:47 AM
ZYA_LTR's Avatar
Well, i think your 120 lbs is a little on the generous side, it's closer to the 70/75 lbs, whoever told you that, probably sold you the holley intake, dude, do yourself a favor, and sell it, you'll have tons of problems, and heat soak to add it all up.
Old Jan 24, 2003 | 08:42 AM
SS00Blue's Avatar
Hmm... Danny's "Teching In" with a whopping 23 posts, fellas. Maybe he really doesn't know...
SC
Old Jan 24, 2003 | 09:11 AM
CHRISPY's Avatar
ARE has run over 1000RWHP through their resleeved blocks for 2 years now.
Chris
Old Jan 24, 2003 | 09:34 AM
jleews6's Avatar
I haven't been around ls1's for that long so i can only speak from what i have seen on other cars and not my own.However i know a guy that has a twin turbo vette that puts down 700 rw and he drives it HARD and has never had a problem.The car runs low 10s @ 140+ and is very reliable.I think most of the problem is in the tune not the strength of the block.I have seen many guys split a stock 302 block at the 550 hp level and then i have seen some of them live at 650 hp for a long time.
Im building an iron block because it cost almost $3000 for an aluminum block all machined. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Jan 26, 2003 | 07:37 AM
2001WS6Vert's Avatar
Like Chris ARE 360 said, I have talked to Agostino, Katech + others and the high horsepower numbers that are being made with the aluminum blocks prove that they hold up. I am sure that an iron block is stronger but is it neccessary. I feel that because everybody knows that the iron is stronger they feel it is something they need. Can anybody show where an aluminum block failed? Most all super high horse racing motors are now aluminum. When I talked to Agostino they just laughed because of all the high horse motors (800 HP+) they have built and raced over and over that held up fine. If aluminum is doing the job why carry the extra weight?
Old Jan 26, 2003 | 09:29 AM
Moderator
No one said you couldn't get an Alum block to handle the power... I'm saying it's cheaper to use an iron block and that those race cars you are talking about are using an Alum block designed for racing. It's probably nearly twice the cost.
In your rebuttal, make sure you are talking about an Alum block capable of being bored and stroked to 422 or more CID.
