Building the best FI motor?
Old Mar 8, 2003 | 10:42 PM
2FAST4U's Avatar
Default Building the best FI motor?
Ok I need lots of help I want to build the best FI motor. I would buy rob's but it is tax time for me! But I am basically looking for the same thing. I want all the power but in a street car so I think I will just adjust the boost. Why bore it? and if so why not 427ci+? What is the Incon kit max boost (16)? So tell me what you guys think everything from cam,heads,block, and important parts. Any help would be great! Should I just call ARE? I have 73cfm 6.0l heads,5.7 heads,and stock ls1 & iron 6.0l blocks As well as 2 600hp turbos and 2 800hp incon turbos!
Old Mar 9, 2003 | 08:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Building the best FI motor?
What are your goals?
Drag racing a lot?
Running a beefed rear end?
Will you be willing to beef up a trans and also run a built up fuel system?
Old Mar 9, 2003 | 09:47 PM
2FAST4U's Avatar
Oh I guess I didn't think about that, I have the walbro fuel pump and injectors 42lb. I want the best and if it can't run then I will change parts or turn down boost, as far as racing I am going into road corse, but street race every weekend so want the power. OH, I have a KTRE 12bolt with a 6speed and money doesn't matter after april!
<small>[ March 09, 2003, 09:48 PM: Message edited by: 2FAST4U ]</small>
Old Mar 9, 2003 | 09:55 PM
BIGBOS's Avatar
It depends on how much $ you want to play with as well..
I plan on doing a cheap 346c.i. build up.... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
But it will handle 15psi..... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 9, 2003 | 09:58 PM
2FAST4U's Avatar
That sound good what is cheap less than 5k I am already runing 10-11lb boost at 500hp if I could brake 800 That would make me very very happy.
Old Mar 9, 2003 | 10:01 PM
BIGBOS's Avatar
Well I plan to spend 4000 for my motor build up, probably a little more all depending on what little parts I decide to add while I'm in there..
Always get caught up in the "while the cars in the shop I'll do this" type of deal... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 9, 2003 | 10:05 PM
2FAST4U's Avatar
BIGBOSS why not go bigger like 396 or 427? Just wanted to know why.
Old Mar 9, 2003 | 10:08 PM
BIGBOS's Avatar
I would no problem if I had the dollars for it... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 9, 2003 | 10:42 PM
VINCE's Avatar
Shorty Director
The bigger the motor the more fuel that is going to be needed to supply the horsepower levels that are going to be produced with 10lbs or more boost.. A built 346ci is enough motor to handle your needs..
Old Mar 9, 2003 | 11:11 PM
2FAST4U's Avatar
so the 346ci is the cheapest way go,no rebore/resleave! But power levels at what mid 600hp! That is about what harlen has a forged 348ci and Incon twins! That sound good for now... What can be done to NOT lift the heads and is ringing the heads to keep from blow out?
Old Mar 10, 2003 | 06:02 AM
smokinHawk's Avatar
How come your converting your car into a drag car, or you still want it xcross?
you could do something like Harlan, built 348 with 700rwhp, this will keep the car lighter, but if you want 800rwhp+ you'd need 400ci+ probably an iron block would might hurt your Xcrossing ability.
Why not get another car and build that into a street/drag car?
or can make you current drag car streetable and use that.
Old Mar 10, 2003 | 11:23 AM
LS1Tech Co-Founder
800rwhp = built motor, 83 lb injectors at least, and an aftermarket pcm to control it all. You will need a complete fuel system as well, like dual intank pumps or a big external pump like the Weldon 2025 that I will be running.
You can do a 400ci motor you will make more power NA than a 346ci and then can make less boost to hit the same number.
Old Mar 11, 2003 | 12:44 AM
2FAST4U's Avatar
Hey I am still autox with that race and have my1000+hp drag racer but what lots of power for my street/autox car. Allright I will go with A LS6 348ci forged block with stock big ported heads. And shoot for a max of 700hp. Thanks guys!
