Copying the Incon TT kit
Old Dec 21, 2005 | 04:11 PM
  #41
peter@aps's Avatar
Originally Posted by XJGPN
There would definitely be tons of interest for that as long as they used a standard T3 or T4 flange so that we can use readily available turbos.
I don't know if there's sufficient room to package a T3/T4 sized turbine housing in the original incon turbo position, that would need to be thoroughly investigated and thats very difficult to do without having access to an F body car. I know that a T28 style single entry turbine housing will fit for sure, a 50 lb per minute GT series turbocharger would be the best/easiest install for sure.
Peter
Old Dec 21, 2005 | 04:18 PM
  #42
slow's Avatar
Do you really think that people will pay $10,000 for a twin turbo kit, incon style from a reputable source?
An incon kit has over $1000 in silicone hoses, expensive cast manifolds, to do it right, you need a $400+ scavenge pump, not to mention the twin ball bearing turbos' close to a 1000 a pop.
This kit will cost more than many of these cars are worth
Ryan
Old Dec 21, 2005 | 04:35 PM
  #43
SS2win's Avatar
having manifolds on the market would be good. fitting a larger turbo would be tough as there is barely room for the gt28's
Old Dec 21, 2005 | 06:42 PM
  #44
SScam68's Avatar
Ryan
The same can be said about turbocharged Fox body mustangs, but there is definitely a hot market for those cars.
Kits are easily worth 2 sometimes 3 times that of the car.
Old Dec 21, 2005 | 06:56 PM
  #45
slow's Avatar
Fox mustangs are also a great platform for drag racing, coming in at under 3000#'s for the coupes with a 8.8 rearend from the factory.
Most incon kits sell for under 3K on ebay for fox TT kits when they pop up every few months.
Ryan
Old Dec 21, 2005 | 07:52 PM
  #46
V8_DSM_V8again's Avatar
Originally Posted by LSONE
I would definitely be cautious about sending someone my money beforehand, but sending my money to a company that employs a man that has basically stolen tons of money from our community, and then flew to another country to escape his problems is definitely out of the question. I might be interested in cast manifolds somewhere down the road though, as long as there were readily available turbos.
I did'nt know about that..
Somethings are prepay. Try to get a one of a kind custom comp cam without ponying up the cash first...
Old Dec 21, 2005 | 08:39 PM
  #47
Wet 1's Avatar
No doubt! Actually, had I been one of those guys that got screwed, you'd see me flying down under looking to throw that MF off the reef, using his *** for shark bait!
Old Dec 21, 2005 | 09:28 PM
  #48
Phate's Avatar
Ryan
If you are talking about the Incon kits for the mustangs then 3k might be accurate, but I have never seen a complete F-body kit for anything close to that. Most of the F-body kits that I have seen sell go for close to, or over what they cost originally.
I sold my F-body kit about 9 months ago (larger CHRAs) for $6500.
Old Dec 21, 2005 | 09:31 PM
  #49
slow's Avatar
I was comparing them to the market of the Fox cars, I know that incon parts are high dollar for the f-cars, used $4500-6500 is not uncommon.
Ryan
Old Dec 21, 2005 | 09:39 PM
  #50
How much do you think some really HQ tubular manifolds would be worth...
I'm talking 321 SS
Double slip collectors T3.
HQ turbo to block mount bracket...
I mean really nice and TIG welded from the best components.
Old Dec 21, 2005 | 09:50 PM
  #51
peter@aps's Avatar
I'm talking 321 SS
About $250 per manifold in production volumes.
Peter
Old Dec 21, 2005 | 10:23 PM
  #52
Peter
Way too cheap.. I'll have $250 per manifold in just the collectors and even straight tubing will cost $16 a foot...
GOOD longtube production headers go for $800 a set...
I am going to make a boiler plate version from mild mandrels to get the bends on each primary right and have a stainless tubing shop bend one piece primaries.
The only welds on the primaries will be at the head flange and the wire tabs for the collectors springs..
As nice as they will be and the work that goes into them means I better MAKE $250 a side..
Old Dec 21, 2005 | 11:16 PM
  #53
will62085's Avatar
dude, there only worth what someone will pay...and i dont see the need anyway considering the great ptk kit thats available that DOES retain the ac and all accesories...along with the budget manifold kits...and if someone wants just manifolds to make a kit with, they are competent enough to make a truck manifold single kit, personally the only market i think there would be for another mass produced kit would be for a tubular header design twin top/front mount kit for the guys who want to show off their turbo system and go fast...
Old Dec 21, 2005 | 11:26 PM
  #54
Well the car I'd be mocking them up on would be getting a top mount with my headers..
The rear mount was just another idea of something to do since I'll have a car to proto stuff on..
So really high flowing, tough and good looking top mount headers would be a good product?
Old Dec 21, 2005 | 11:45 PM
  #55
LSONE's Avatar
talk about apples to oranges!
You're really trying to make a comparison between a relatively small amount of money, up-front deposit on a well established American company verses sending several thousand dollars overseas to a company of unknown financial stability, employing a man who has screwed his fair share of people walking in the very same f-body circles as you or I? hardly comparable, IMO. If come cams started making cast turbo manifolds i wouldn't think twice about sending my money to them.
Old Dec 21, 2005 | 11:55 PM
  #56
You're really trying to make a comparison between a relatively small amount of money, up-front deposit on a well established American company verses sending several thousand dollars overseas to a company of unknown financial stability, employing a man who has screwed his fair share of people walking in the very same f-body circles as you or I? hardly comparable, IMO. If come (SIC> comp) cams started making cast turbo manifolds i wouldn't think twice about sending my money to them.
I did'nt have a clue about the prior deeds of their employee...
Also I dont think just a pair of manifolds will amount to several thousand dollars...
Comp is'nt the only company. Try buying anything mail order and say I will pay you after it has been delivered..
Old Dec 21, 2005 | 11:58 PM
  #57
Quickin's Avatar
why hasen't a reputable shop like LPE made a TT F-Body kit yet?
Old Dec 22, 2005 | 12:14 AM
  #58
camcojb's Avatar
Well, I ordered my kit from APS, wired them the money ahead of time. It shipped exactly as they said and the quality is outstanding.
Jody
Old Dec 22, 2005 | 12:30 AM
  #59
APS has quite a following on the import scene...
I personally plan to do one install using some techniques used on aircraft...
This is a local company that is actually doing colectors for laser shop right now.
I am going to be getting my components from there...
Aircraft exhaust however engineer things the same for a LS1 f-body and it will be light, indestructable and flow very well..
Notice the double slip collector and ball joints on the primaries?
Old Dec 22, 2005 | 07:44 AM
  #60
RyanJ's Avatar
SSU Moderator
The only way anyone is going to make money is if Peter/APS can get the cast molds cheap and sell them as is and alone. I can see people paying $1300-1500 for cast manifolds, but a whole kit would get unruley real quick. In terms of price and development.
