Making progress on phamspeed kit
Old Mar 19, 2006 | 05:39 PM
WestSide's Avatar
Default Making progress on phamspeed kit
I have the WG, BOV and fan...just need little odds and ends and I can hopefully start it up this coming weekend or the following. I of course need to upgrade the clutch and fuel...clutch is being ordered next week
I wish I didn't have to route under the kmember but A/c and p/s are worth it to me.
Old Mar 19, 2006 | 05:44 PM
98turbls1's Avatar
Is your car lowered?? If so then you may have some trouble with the pipes..You probably already know that though...Looks good though..When are you going to have it done??
Old Mar 19, 2006 | 05:45 PM
WestSide's Avatar
Not lowered at all...I will lower it when I'm done with the kit, but only an inch or so. I drive the car maybe two nights a week...not a daily driver by any means.
Hopefully should be tuned and all by May I'm sure.
Old Mar 19, 2006 | 06:38 PM
dubrado's Avatar
daaaaaaaang, that **** is hot
Old Mar 20, 2006 | 06:21 PM
WestSide's Avatar
Do you think it's sitting too high? I'm going to cutout the whole frontpiece, basically the shape of the black grille insert.
Old Mar 21, 2006 | 06:22 PM
WestSide's Avatar
Got the turbo in
Old Mar 21, 2006 | 07:09 PM
Slowhawk's Avatar
LS1Tech Sponsor
It doesn't look too high.Does the bumper even fit with it like that? I've always got rid of the bumper support.
Old Mar 21, 2006 | 07:45 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
when you get the alt mounted post up a top view pic i wanna see how close it is to the VC.
Old Mar 21, 2006 | 08:57 PM
WestSide's Avatar
My "test fit" proved to almost (if not partially) touching the vc.
I'll get a pic up tomorrow hopefully.
Slowhawk, I haven't been able to put the front end on, just kind of eye-balled it on there and it'll be a snug fit im sure, but if it's too tight i'll pull the support.
Old Mar 22, 2006 | 09:43 AM
nastysupaspt's Avatar
What kinda intercooler is that? ITS SWEET!!!!!
Old Mar 22, 2006 | 10:12 AM
ddnspider's Avatar
looks good,you passed right by me!lolwhat are your goals?
Old Mar 22, 2006 | 12:38 PM
WestSide's Avatar
~9lbs boost. I'd be pretty happy with mid-to-high 500's to the ground. I should have plenty of fuel as well as methanol.
Old Mar 22, 2006 | 01:51 PM
Slowhawk's Avatar
LS1Tech Sponsor
Just saying we used that intercooler on a TA and the end pipes were extremely close to the nose cone.That was without the bumper support.
Old Mar 29, 2006 | 02:02 PM
WestSide's Avatar
This is where the charge piping from the intercooler to the maf is supposed to go.
Old Mar 29, 2006 | 03:12 PM
Dr.x's Avatar
do you have to cut a hole to let the charge pipe come up through?
Old Mar 29, 2006 | 09:04 PM
ddnspider's Avatar
if your talking about in the foam support than no,and from mocking my stuff up it doesnt appear that you do,westside can chime in if he did differently
Old Mar 29, 2006 | 09:26 PM
WestSide's Avatar
No, I had to pull the fuse boxes out a bit...probably going to mount them apart to make the squeeze a little easier. It does fit, though.
Old Apr 1, 2006 | 01:14 PM
WestSide's Avatar
Old Apr 1, 2006 | 01:16 PM
WestSide's Avatar
Got the alternator to finally fit, had to do some cutting though. For all you guys who want an alternator relocation...talk to smokinHawk, seems to me his fit better than what I have, and without modification I believe.
Also cut out the front grille area...I'll post that picture up later.
Old Apr 1, 2006 | 02:45 PM
WestSide's Avatar
