Iat??
Old Sep 12, 2006 | 06:15 PM
SINISTER's Avatar
Default Iat??
6.0 manifold setup what do u do about the IAT sensor
leave it unplugged an turn it off in the computer?
doesnt it have to go before the turbo?
little help plz?
Old Sep 12, 2006 | 06:47 PM
qqwqeqwrqwqtq's Avatar
Get a threaded sensor and install it in the induction just before the throttle body.
Old Sep 12, 2006 | 06:53 PM
Country Boy's Avatar
Senior Member
part number for said sensor?
Old Sep 12, 2006 | 06:57 PM
I don't know the part number offhand, but we have them at Speed Inc. and I believe we get them from F.A.S.T.
Old Sep 12, 2006 | 07:07 PM
frcefed98's Avatar
GM #25036751 is the PN I have in my reference file for the threaded IAT sensor. Probably right.......
Old Sep 12, 2006 | 07:08 PM
Bird-Of-Prey's Avatar
You can use the IAT from the GMC Cyclone. It is the threaded one and I believe it's the same one that comes in the procharger kit. My local Autozone had one for under $20
Old Sep 12, 2006 | 07:41 PM
SINISTER's Avatar
thanks guys got one from advanced for 7 bucks
also would having this unplug cause a disruption in the map sensor
im showing a map sensor code check engine light never had one before and this iat sensor is the only one thats unpluged since the swap to my own kit other then the tti one
Old Sep 13, 2006 | 06:55 PM
MiaSSmaro98's Avatar
can u actually disable it?
Old Sep 13, 2006 | 08:23 PM
You don't want to leave it unplugged. I don't think you can disable it nor do you want to. It's very important to know the actual intake temps because it plays a very important role in your ignition timing. The cooler the intake temp, the more the timing is advanced. Forget about the Ebay IAT mod. It's a joke and can only hurt you. With the IAT not reading you might get too much ignition timing and run into detination. Or worst case scenerio BOOM!
Old Sep 14, 2006 | 12:45 AM
bird of prey have u started ur car yet i wanna hear the cam
Old Sep 14, 2006 | 11:48 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm sure the car will run crappy if you don't have the IAT working.
Old Sep 14, 2006 | 03:18 PM
The AntiRice's Avatar
you will definately want to plug your ait in, if you have ever looked at your bin file in your pcm you will see there is a spark as well as a fuel table that use the readings from that sensor to calibrate timing and fueling based on its readings.
Old Apr 12, 2008 | 08:43 PM
zmonsterjb's Avatar
I wonder about this, I accidently left mine unplugged while retunning my olsd car and it runs fine without it, a lil better seems like.
