The numbers are in: 576 rwhp @ 4.5 psi SAE
Old 10-30-2006, 11:38 AM
Willem @ Fuel Injection Concepts's Avatar
Default The numbers are in: 576 rwhp @ 4.5 psi SAE
Done on a Mustang dyno with SAE correction, only 4.5 pounds of boost, unported 317 heads and stock shortblock. Twin T3 GT35's.
TT C5 Vette with Hi-Flo kit, on pump gas.
Old 10-30-2006, 11:42 AM
KraZy's Avatar
Damn those numbers are high - I didnt even get 500 w/ 7lbs (auto though)
Old 10-30-2006, 12:07 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,162 Likes on 756 Posts
Nice numbers, what is the longblock?
Old 10-30-2006, 12:13 PM
stock block, unported 6L heads, stock pushrods, stock valves, my own dual valvespring kit, and a secret cam.
Old 10-30-2006, 12:17 PM
i will note that the cam and the turbine housing a/r are generally considered unorthodox for a turbo street application, but ended up working great like i thought. the power curve is very easy to handle as it is almost like a centrifugal blower car but with alot more torque.
Old 10-30-2006, 12:34 PM
KraZy's Avatar
You sure there isnt a stroker crank in that stock engine? lol
Old 10-30-2006, 01:06 PM
Turbo LS1 SS's Avatar
damn that seems TOO high. ive never seen numbers this high for similar builds...
nice work william
Old 10-30-2006, 01:09 PM
NemeSS's Avatar
post up dyno graph
Old 10-30-2006, 01:15 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Originally Posted by NemeSS
post up dyno graph
Plus 1.
Old 10-30-2006, 01:35 PM
bboyferal's Avatar
nice work william
On a Mustang Dyno to boot... Any other secret ingredients aside from the cam?
Old 10-30-2006, 01:44 PM
RW99's Avatar
I quit.
Old 10-30-2006, 01:50 PM
99SS-T's Avatar
Im amazed at thoese numbers. I think something is amiss. I cant imagine how a turbo kit even made by God would make that amt of power at 4.5 psi. Even if ur secret cam is gigantic something dont add up. Most are around 8psi and 500 rwhp. So spill the beans!!
John
Old 10-30-2006, 01:54 PM
qwikz28's Avatar
open wastegate?
Mike 01WS6's Avatar
Large turbos, make more power at less boost than two 28's or 30's that people typically use. Not too often you see a set of GT35's strapped up to a motor, a stock one at that. Those numbers seem possible with that setup. Of course...they could just be icing the **** outta that intercooler too....
Old 10-30-2006, 01:55 PM
Frost's Avatar
Even at 30HP per PSI (4.5*30=135HP) that puts you starting at nearly 440RWHP on the same MUSTANG dyno.
Even with a graph, how can 4.5 be believed? Don't get mad; anything that's true stands up to honest scrutiny.
Old 10-30-2006, 02:03 PM
My theory is that the big cam is just making the VE so high that the boost numbers appear low. Plus, what the other guy said, i'm using larger turbos than most people use on a stock motor setup.
Old 10-30-2006, 02:05 PM
LS1Tech Co-Founder
On SP's dyno Bill?
Old 10-30-2006, 02:09 PM
Yes, but I swear it's not a happy dyno! Several other vettes have dynoed their with very realistic numbers, and right before I dynoed a Supra I know made very conservative numbers.
Old 10-30-2006, 03:37 PM
bill ur comin over to buffalo in the spring for a bbq/cruise day..... no if ands or butts. in fact, anybody in the area come once i organize it
Old 10-30-2006, 03:52 PM
do they call them buffalo wings there or just chicken wings?
Quick Reply: The numbers are in: 576 rwhp @ 4.5 psi SAE
