STS gains
Old Feb 5, 2007 | 04:43 PM
  #41
smoke20's Avatar
Originally Posted by enginjoe
Except for nitrous, how could you get there any cheaper or easier and have the same street manners, gas mileage and cool turbo sounds?
exactly my thoughts.. i have two friends both n/a and they have more in there cars with heads,cam and 90/90 and i walk em both plus i have room to grow they are running out of things to change -- except the juice
  #42
ZL1Killa's Avatar
baby bottle ... got to refill it
Old Feb 5, 2007 | 04:54 PM
  #43
JD_Z28's Avatar
My car ran a 7.401 @100 mph w/9psi and a 1.8 60ft. I never had a chance to test it in the 1/4. BTW this is with the stock 60-1 .96A/R.
Old Feb 5, 2007 | 05:04 PM
  #44
smoke20's Avatar
i had the .96 A/R and i switched to the .81 A/R and the response was awesome, i also have the bigger 67 turbo .
Old Feb 5, 2007 | 06:22 PM
  #45
99Z28LS1's Avatar
i have the .96, i wanna try the .81
Old Feb 5, 2007 | 07:12 PM
  #46
ZL1Killa's Avatar
All You **** Talkers Go **** A Goat
Old Feb 5, 2007 | 07:33 PM
  #47
vandal0-0's Avatar
I have a 2000 camaro with a 408,th400 tranny,fmic,and meth inj.Car made 550 horse at 13lbs of boost and was floating the valves.Changed the valves now the car makes 16lbs of boost but is running lean so im redoing the fuel system as we speak.This is with a t-70 turbo STS kit.
Old Feb 5, 2007 | 08:16 PM
  #48
JAvenger007's Avatar
Hows the spool with the .96? Ive got a .96 but the car has never seen a true WOT pass. Smoke how much improvement did you see in spool with the .81 (in rough RPM estimates).
Vandal you should be makin a lot more power than that with a 408 at that kind of boost. Get some stronger valves and throw her back on the dyno. You should be seeing 650+ at 16psi.
Old Feb 5, 2007 | 08:53 PM
  #49
JD_Z28's Avatar
I have a 76 comming in this week but I'm still goanna be running the .96. I want topend power and everybody says the .96 works great at sea level. I get full boost at 3500 RPM's.
Old Feb 5, 2007 | 10:37 PM
  #50
99Z28LS1's Avatar
i love your car
Old Feb 5, 2007 | 11:00 PM
  #51
JD_Z28's Avatar
Originally Posted by 99Z28LS1
i love your car
Thank You Sir. I love your car too
Old Feb 5, 2007 | 11:31 PM
  #52
enginjoe's Avatar
ROFL
Old Feb 6, 2007 | 06:13 AM
  #53
smoke20's Avatar
the difference between the .96 and .81 was where the boost started. the .96 was a lagg hog. but when it came in it stayed especially up top, car had slow track times but was faster through the trap, with the .81 reponse was much quicker, track times picked up but i lost trap speed. i would guess because it was a year and a half ago but somewhere around 300-400 rpm difference in full spool. i also had a 3.73 gear and now im a 3.23 to load turbo.
Old Feb 6, 2007 | 08:12 AM
  #54
ZL1Killa's Avatar
well i'm going to a 3.42 , i will be having a IC made up custom, and should i go with a smaller a/r ratio(currently the stock STS .96)..maybe go to a .81? mine spools by around 3400 if not a little higher...have to go back home and drive it and see again, lol. its been a while
Old Feb 6, 2007 | 08:49 AM
  #55
smoke20's Avatar
i full spool by 2800-3000 rpm now i was at 3500 like you, the two fastest STS turbo f-bodies on here are longrange4u and zombie, they both are running very tall gears. thats why i went with 3.23 and it pulls very hard for a long time , keeps turbo loaded up.
Old Feb 6, 2007 | 10:33 AM
  #56
JD_Z28's Avatar
Good to know I think I like the higher topend and to make up for the low end I might just set the 2 step higher
Old Feb 6, 2007 | 11:19 AM
  #57
99Z28LS1's Avatar
i debated on using 2.75's because i do my races on the highway...... but if i ever get the money to get all new clutch and rear, i would go with 3.23's and use a 2 step like you JD_Z28
Old Feb 6, 2007 | 12:13 PM
  #58
JD_Z28's Avatar
The 2 Step works great. I know if I went to a good track and hooked up I should be able to cut 7.1-7.2's in the 1/8th, with the new turbo who know how it will do
If you like highway runs I'de say go with the 3.23's and bigger A/R FTW
Old Feb 6, 2007 | 12:23 PM
  #59
Zombie's Avatar
The best for highway is a th400, 2.75 gears and a fairly tight stall. The larger a/r works better with an auto because boost never falls off during the shift.
FWIW my 1/8 mile is 6.7 @ 104 with a 1.58 60' I love the trans brake, 10psi launch. 14psi boost.
Old Feb 6, 2007 | 01:28 PM
  #60
JD_Z28's Avatar
But wouldn't you run out of gearing? what speeds could you reach with a 3 speed th400? I love my manual gear box
