? for STS guys
Old Feb 5, 2007 | 10:00 PM
Adam98Z's Avatar
Default ? for STS guys
I'm new here, but have been reading up on this site for a few weeks. I am doing my first f-body build and have a simple ?, I hate asking the "what mods for what hp ?'s" but this isn't exactly one of those.
I have a Callies 383 9.0:1, fast 90mm intake, a custom Bauer turbo cam (getting ground now, no specs on it, but lifts should be upwards of .600, 114lsa), Dart 225 heads, Pacestter lt's, and FMIC. I had been considering just the base STS kit, but I want to make sure it can put down the numbers I want. Should I look to upgrade the turbo to help make ~650whp, or will it be capable of it on it's own?
TIA,
Adam
Old Feb 5, 2007 | 10:10 PM
NYSS Guy's Avatar
If it helps at all, I had to go with a T76 for my setup. If you get the base kit, the 60-1 will max out way below the #'s you're looking for.
Old Feb 5, 2007 | 10:12 PM
trtturbo's Avatar
The 67 would be done at that level. You could do the 70 and it will get you your 650.
Old Feb 5, 2007 | 10:33 PM
99Z28LS1's Avatar
listen to the people above, they know their STS kits
Old Feb 6, 2007 | 09:13 PM
Adam98Z's Avatar
thanks for the help guys, going with the t70
Old Feb 7, 2007 | 11:25 AM
Tiger2o69's Avatar
how much more can you get out of the t70 than the 67?
Old Feb 7, 2007 | 11:58 AM
99Z28LS1's Avatar
you can get the 67 to 650 i think and the 70 will go to 700 or 750..... dont quote me on that
Old Feb 7, 2007 | 03:04 PM
pdanrichey's Avatar
With that "low" of compression and the bigger engine, I say go for a larger turbo. I'd hit up the 70 in case you wanted to upgrade down the road. According to EPP (I believe), the t-67 maxed out around 13.5 psi and they made 700rwhp with 9.0:1 compression...plus all the interal goodies that go with a nice engine rebuild/overhaul...
Old Feb 7, 2007 | 04:57 PM
OUTLAWZ RACING's Avatar
I went with a gts 76 from jose at force inductions
Old Feb 7, 2007 | 05:07 PM
trans2000am's Avatar
EPP got 700 hp on 67mm was on a 383 though.
Old Feb 7, 2007 | 05:34 PM
pdanrichey's Avatar
That's what this dude has...a 383 with 9.0:1 compression. See the original post.
Old Feb 7, 2007 | 09:26 PM
ZL1Killa's Avatar
trt knows..... trust me
Old Feb 11, 2007 | 09:28 AM
Tiger2o69's Avatar
I have a 67 and hate to lose all the money in doing an upgrade. Ill probably stick with 600-650 hp for now. I may spray a little nitrous on top of the turbo tho.
At the 600-650hp levels what times are the sts's running? It seems they run a little slower than most 600hp cars..
Old Feb 11, 2007 | 09:53 PM
Adam98Z's Avatar
I am wondering the same thing.
Old Feb 12, 2007 | 12:28 AM
Zombie's Avatar
Don't play around with the small turbos on that size motor. Go straight to a .81 T76 GTS, ditch the long tubes and put stock manifolds back on it and the car should run good.
Why such an extreme cam? Even with a T76 your shift point will be about 6000 rpms on that size motor. Stock cam or a z06 cam would be much nicer to drive.
Old Feb 12, 2007 | 01:39 AM
99Z28LS1's Avatar
listen to zombie, a proven STS guru
Old Feb 12, 2007 | 02:57 AM
Adam98Z's Avatar
Just trying to meet an initial goal of ~650whp with the ability to grow way past that in the future. It'll be easier if I want more power to upgrade the turbo, as opposed to a cam swap. And since this isn't a dd I am not too worried about streetablility with it.
What I have listed in my first post is my guesstimate of where I think it might be at based on what I wanted from the Bauer guys. I asked for decent manners but to take advantage of the heads, so it'll probably be a little smoother than that. I should have the exact specs on the cam very soon and I'll post them.
BTW I appreciate the input guys.
Old Feb 12, 2007 | 03:28 PM
Zombie's Avatar
Not neccessarily me, but my friend who built a lot of my car and my willingness to experiment and waste $$ trying things like a dumb ***. Then admit defeat or success on the forum.
Old Feb 15, 2007 | 10:55 PM
Tiger2o69's Avatar
thats a smaller turbo in your sig.. is it a multidisc? If so I would assume you have a trans brake?
Your running stock ported and coated manifolds?
Has anyone tried shorty's or mids? Just rather have them if they will work well?
Old Feb 16, 2007 | 11:56 AM
Zombie's Avatar
I'll assume by smaller multidic turbo you mean my converter. I don't think it has any discs since it's for a Th400. I do have a transbrake, I would not put a th400 in a car like this without one.
