F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
#1482
Originally Posted by TNTramair
yeah i heard of a few issues, but than again, there are people running other heads that are having the same trouble so who knows if its really a head issue or headgasket/torqueing issue etc.etc. mine wont see serious boost so i should be fine (10-12psi)
but if it becomes a huge issue i can allways replace them and chalk it up to a lesson learned.
Peter
#1484
Originally Posted by Big Bird WS6
One Word.
AFR
sorry i have used both L92 stuff and AFR stuff. gm is good, but not that good. there is just more mass to the AFR.
yes bang for the buck. L92
Quaity that last AFR
just ask tony. he wont lie. didn't to me.
AFR
Peter
#1485
Originally Posted by Inspector12
How close are you to shipping these kits Peter? Are you guys still on target?
#1486
Originally Posted by peter@aps
Thanks for the update. APS is going with Mahle forged pistons and AFR 225 heads (static comp ratio should end up around 9.2:1) and a GT11 turbo cam in our LS1 forged engine, should be interesting to see the final power and torque results.
Peter
Peter
#1487
I like your power goals and engine specs (especially the 9:1 comp ratio) How do you think the stock drive train will handle 700/700 rwhp/rwtq? Interested in your thoughts and do you have any plans to strengthen the drive train?
Peter
Peter
#1488
Originally Posted by Brains
Just upsize the "standard" turbochargers and call it a day
Peter
#1489
yeah..the rest of the drivetrain is still stock and its gonna take a beating. im gonna run a Textralia exoskel clutch with the stock stuff untill the rear or trans decide to give up on me. after that...im going with a 9" and than a built T56.
Not trying to wish bad things on anyone..... but if you ever put a tire on this car; I got dibs on the diff ending up in 43 pieces LOL.
#1490
Originally Posted by JMBLOWNWS6
LOL Kinda makes me not want to install the kit till bigger turbo's are available But that wont happen!
Peter
#1492
Oh... and the LSx Mustang I PM'ed you about, the motor is already built. 347cid LS6 block, Probe pistons, Eagle rods, stock 241 casting heads with a basic port job from Bo White (stock valves), LS6 intake manifold and stock throttle body. It's your run of the mill 8.8:1 compression ratio forged motor. The transmission is a built 4L60e, with a Precision Industries Vigilante 3200 RPM converter -- we'll see how long it lasts, then I'll go built 4L80e. The rear end is still an 8.8, but it has 31 spline Moser axles, C-clip elims, etc. I'll test-fit the F-car kit on there before it gets installed on the Firebird, and if things fit well I'll be in touch about another kit
Thanks,
Peter
#1493
Peter
#1495
Guys, Here's the first pic of the APS F body twin turbo system MAF delete hose, this part will be released by the end of Sept 07 if all goes to plan, enjoy! Do you guys like the steel reinforcement rings on ther MAF delete hose? This will ensure that the moulded 4 ply nomex reinforced silicone hose can cope with quite high boost pressures.
Peter
Peter
#1496
Here's another pic of the MAF delete hose, enjoy!
http://www.airpowersystems.com/fbody/maf_d_1.jpg
Peter
Peter
#1498
Still on target for shipping F body twin turbo systems between the 15th to 17th of August 07. Around 30 systems will ship between those dates and the balance of twin turbo systems will ship a few days later. I will of course keep you all up dated on the actual despatch date and I will email out the final payment form to all of the guys in early August so there's no delays in getting the TT systems shipped out to you guys.
#1499
Originally Posted by fil131
What do you mean by a few days later? Please dont try to sugar coat it, I want your honest opinion on how long the remaining 20 units will ship after the first 30 are sent out.
