Vortech @ 7lbs - 520 rwhp
LS1TECH Sponsor
We just finished a stock bottom end Vortech with after cooler. Here are the results:
The car has ARE stage 1 heads and a small cam, FLP headers, Flowmaster, Rapid Tuning.
![](http://www.rapidmotorsports.com/ritter-dyno.jpg)
LS1TECH Sponsor
Good numbers, but I know a certain T/A with twin turbos and a stock bottom end that is running 136mpg trap speeds. This prolly equates to 600+ rwhp on a dynojet.
Any idea why the graph is a ittle wavey Mikey?
Looks pretty close to my graph, without the wavy lines. Mine actually showed 8PSI at 6600RPM, and the HP graph was still going straight up.
Good numbers!
Good numbers!
[quote] WOW thats excellent gas mileage especially out of a twin turbo T/A. j/k i know what you meant
PROBABLY HIGH 10S LOW LOW 11S @ 123-125 IN A FULL WEIGHT F-BODY.
I think I can do it with 4.10s, 28" slicks and skinnies, and the harlan 2-step. I can shift fairly well, too.
how long will this last on a stock bottom end though?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Great results. ![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
I'm looking forward to getting the dyno numbers on my V9 kit soon. The motor is otherwise totally stock, with only a modified (no muffler, straight 3" pipe) SLP dual dual exhaust and bottom of the airbox cut out.
I'll post 'em after the trip to the dyno.
