Which Supercharger?
Old Aug 11, 2007 | 06:03 PM
JEB99TA's Avatar
Default Which Supercharger?
I have 347 forged motor, would the D-1SC be my best choice from the choices below? I have AFR 205's (arp head bolts) with upgraded dual comp springs and FAST 90mm intake. And would the 224/228 .581/.588 114+1 degree be OK? I'm new to this and don't know a dang thing about it ... never had a power adder of any kind before.
P-1SC-1
Centrifugal
825
32
1200
Gear Drive
65,000
3.75"
2.62"
Yes
Street/Light Duty Race
P-1SC-2
Centrifugal
825
30
1200
Gear Drive
60,000
3.75"
2.62"
Yes
Street/Race
D-1SC
Centrifugal
925
32
1400
Gear Drive
62,000
3.75"
2.62"
Yes
Street/Race
F-1
Centrifugal
1050
38
1525
Gear Drive
70,000
3.75"
2.62"
Yes
Street/Race
Old Aug 11, 2007 | 06:37 PM
98transguy's Avatar
depends on what your goals are. KP has gone bottom nines with his d1sc and stock cubes.
Old Aug 11, 2007 | 07:43 PM
SSilverSSurfer's Avatar
i would like to see someone with a D1-R. has anyone used one of those? or know of any one
Old Aug 11, 2007 | 09:09 PM
Websy21's Avatar
D1 all the way
Old Aug 11, 2007 | 09:29 PM
FullBoreTA's Avatar
If you decide to go bigger cubes, then, F1. But, it sounds like you're keeping the 350. D1 will do you well, but, no ro0m for growth if you decide to go bigger motor. If it's 9's you're looking for, they're def acheivable with that setup.
Old Aug 11, 2007 | 09:58 PM
nvmy2000ss's Avatar
D1 is the best setup for your application. you could go F1 but I think it would be overkill unless your looking for higher boost and horsepower. I have close to the same setup your running and made 620-650rwhp and you could still go farther with race gas.
Good luck
Brian
Old Aug 12, 2007 | 12:29 AM
bboyferal's Avatar
347's CR?
Old Aug 12, 2007 | 06:02 AM
JEB99TA's Avatar
My goal is mostly a street-driven DD that will run mid-high 9's. CR is 11:2, so, I'll have to redo heads. If I were to swap out my 205's with 62mm chambers, what kind of millwork would be necessary for a set of unmilled AFR 205's heads? Or will I need different heads? What about AFR 225's?
Old Aug 12, 2007 | 08:31 AM
98transguy's Avatar
u are going to need to get some heads probably with a 72cc chamber.what dish pistons are u running.cr seems high for a dished piston.
Old Aug 12, 2007 | 08:48 AM
JEB99TA's Avatar
It's the pistons that came with the Mahle Power Pak kit below. The pistons were not flycut ... wasn't necessary with my cam.
Bore ... 3.905
Stroke ... 3.622
Rod Length ... 6.125
Pin Dia. ... 927
Comp. Height ... 1.314
Dome Volume ... -2cc
Weight Grams ... 394
C/R 64cc ... 10.0
Part Number ... LS1314905F02
Old Aug 12, 2007 | 09:13 AM
JEB99TA's Avatar
Man, the more I look at this, the cost-effectiveness is going to be killing me because I had my motor initially set up for 150-200 nitrous setup ... that's what the ringlands are set up for, as well.
It's making me think about just doing a 408 with an F1 or a NA 427 H/C crate motor. I really wanna' do forced induction ... any ideas what would be the most cost-effective forced induction route would be for me to take? Like I say, I'm new to the idea of forced induction and don't wanna' do this over again.
Old Aug 12, 2007 | 10:04 AM
Got Me SOM's Avatar
Jeb go with a D1 for now, that' will keep you happy for a while. And you will wonder why you never went forced induction in the first place.
If you can get the compression down to 10:1 with new heads do that.
Otherwise drop the motor change the pistons and put that kit on. You might need to beef up your fuel system.
thought you were selling the car??
If you're going to do a new motor, do an ALUMINUM 402 with the D1 and kick ***!
NA cars suck. lol
If you want i can drop by your house and you can experience my little vortech car, it will give you a clue how much fun boost is.
Old Aug 12, 2007 | 10:30 AM
PREDATOR-Z's Avatar
NA cars suck. lol
I can beat you NA and we could go at it 5>10 times in a row without cooldown, wanna try???
Old Aug 12, 2007 | 10:40 AM
Got Me SOM's Avatar
yea I'll start loading my car onto a plane right now..
think the poster wants opinion on forced induction, back to topic..
Old Aug 17, 2007 | 05:01 AM
JEB99TA's Avatar
Just dug this up ... what do you folks think about it over the D-1SC?
http://www.kennebell.net/supercharge...vette-tech.htm
... designed for LS1, LS2, LS6 motors:
http://www.kennebell.net/pricelist/SC-PRICELIST.pdf
Old Aug 17, 2007 | 06:38 AM
speedracer5532's Avatar
I have a F1A on my 403 and I love it.
Old Aug 18, 2007 | 12:19 PM
JEB99TA's Avatar
I'll bet .... how you putting down 914 RWHP with that torque level? That can be just from the 403 and F1A ... you hititng it with nitrous,a s well?
Old Aug 18, 2007 | 01:20 PM
52172's Avatar
why are you thinking about gong FI if you don't like that statement?
Old Aug 18, 2007 | 01:29 PM
No nitrous and the 914 rwhp was on 15 lbs of boost.
Old Aug 18, 2007 | 05:46 PM
JEB99TA's Avatar
That kinda' power makes me dizzy ... hehe! I see you're in the 10-sec club. Have you not ran it the setup you have now? Or, have you just not taken time to post times?
