My own '99 Hugger Orange Z28 is finally getting put back together!
#121
7 Second Club
TyTy its 9.2:1
Kevin its got the 325 with a 3:70
Its funny that we mad 5 runs making 633 nothing more nothing less and No matter what kind of screwed up pass we made it went 138 in the traps (we made nasty looking passes)We think monday I will put In a buddys 9'' continental and test it down in Memphis Thurs. Good thing is the Tune up is good and nothing fell off the car![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
just so you know... that BS3 that you guys are ordering is coming my way
i may end up needing some help setting it up so you might be getting some calls from me
#122
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
... if it gets here before thursday ill be at the track testing if not ill be visiting with you guys at memphis...
#123
One thing nice about pulls on a dyno is you can see where the converter is coming together. I graphed mpg vs rpm , well its basically a flat line until about 45mph then it sky rockets once the converter engages and then its a 80-85deg line shooting skywards until it hits peak mph.
#124
Tonight at Muncie Dragway the car went 9.989 at 139.86 at 7200 rpm...
The converter's definately a problem. No matter what we did, take timing out, add more timing, fuel, etc, the car would run 138-139 mph every run. It's going through at 7200 rpm to boot.
It didn't help that Muncie had stones on the starting line.
Thanks everyone for the positive comments, we appreciate it! Bob
#125
The car is making an *** ton of power, its just putting it through though the converter. Watching it rip the fronts off the ground is alot different than watching the AWD DSM's shoot out. I have 30+ photos for the night, but I can't seem to find the damn cable... damn messy room.
#129
Cool car, is your car mini tubbed? I was looking at running a set of 325's on my Camaro also was wondering how much yours stick out?
Also just a question about the rims, why run a 15x10 with 6.5 back spacing and not just narrow the rear end more and run less backspace?
What the latest greatest power numbers and 1/4 times?
Good luck =)
Good luck =)
#130
Good luck =)
Good luck =)
This car has the same tires. Stock width rear with 7.5" backspacing. On my car I thought one inch narrower per side with a 6.5" backspacing would look good. I didn't want it to look like the car has deep dished wheels.
We just ran the car for the first time Friday, the engine was broken in on the dyno just Thursday night. We're not going to run the car anymore until we either get another converter or we just take it as is to Memphis. If we get another converter in time, we'll probably do some more dyno runs just to make sure the tune is on and everything is as it should be. Bob
#140
Update: We're going to try a Powerglide that Ted had in his racecar for the LSX Shootout. The same shifter will work, and Ted has a converter that will handle the power without a problem. I Called Tim, Moser's new ace fabricator and told him what we were doing. Tim had a new front torque arm crossmember designed for the glide, it just needed welded. I sent Tony over to Moser's, and it was ready when he got there. Bob
