Progressive Vortech install with Pics and Q's
sounds like fuel level sensor to me regarding the fuel issue.
make sure the drain line is away from the crank pulley or you 'll puke oil everywhere when it cuts open.
Any other questions lemme know.
I think I have some other pulleys laying around if you are interested.
<Rides a Suzuki now.
I just took the pump back out and double checked everything....the swing arm was pinned to the bottom I think. When I started it up it was back to normal.
On the down side I still can't get the stupid water pump for the powercooler to work.
Jeff
Jeff
But anyways the info in this thread is definitely going to help me, post any and all problems you run into so I know whats coming.
Also did you get it tuned? because I am not getting the tuner that Vortech sends you so I may have to trailer it to a tuner before I run it with the new injectors.
From what I hear it wouldnt be wise to even drive the car with no tune after the injectors are put in.
jkI sent my computer to Speed Inc and they did a mail tune set up for the boost and injectors....next tuesday I will take it down to Speed for a dyno tune. Yeah, from my understanding it's a very very bad idea to run your blown car with out tuning. So you may have to do the trailoring idea.
Jeff
I ask because the pump pushes water from the small radiator to the powercooler, so it would be counter productive to be drawing on the wrong one.
It doesn't pay to try and take short cuts and be lazy, I should have just took it out. Is there anything else besides a new radiator that I will need or can I just re-use the lines etc?
Jeff
getting a little old. lol What else can I try? I think I'll re-check my wiring, I doubt that's it though...it's pretty straight forward. Download the instructions from Vortech and check the wiring diagram. Are you sure your grounds are good?
Been real busy at work and stuff so sorry I haven't been able to be responsive.
Enjoying the hell out of riding my Suzuki though.
I ended up finding the issue with the pump, had the relay in wrong. After that it started right up and sprayed everywhere....including all over me
Yeah don't know the story with the coupler but I'll definitley look into those black ones.
