Progressive Vortech install with Pics and Q's
Got the headunit mounted and the the AC and serpentine belt back on.
Removed splash guard to mount the water pump and reservoir tank.
Slight mock up
Just have to secure the reservoir tank, mount and wire relay in engine bay. Then injectors should be done on Tuesday along with the hard piping for the blower/cooler.
More to come......
You could totally do that, I think you would just have to get a longer tube to reach the pump, which is mounted right next to the powercooler radiator.
Got the cooler radiator mounted, still have to secure reservoir tank and hide red pump wire.
Mounted the powercooler bracket with some new bolts I got from F&F, the original ones were too long.
Changing the blower pulley to a 2.95 instead of the 2.75.
Next got the new pulley on, put the blower belt on, and put the fans back in the car. Also put the air box assembly together.
Did a mock up mount of the power cooler. Had an issue with the height..couldn't get the hood to close it sits too high....
Here's the pics first:
Secondly, something happened when I installed my Walbro intank because my gas tank says it's empty and I know that the tank is nearly full, any ideas? I know this is fuel related so i'll do some searching in the fuel section and post if necessary in that forum.
http://video.google.com/videoplay?do...83550061078406
sounds like fuel level sensor to me regarding the fuel issue.
make sure the drain line is away from the crank pulley or you 'll puke oil everywhere when it cuts open.
Any other questions lemme know.
I think I have some other pulleys laying around if you are interested.
<Rides a Suzuki now.
