ATI Procharger users
Old Jan 25, 2008 | 10:08 PM
SCREAMIN01SS's Avatar
Default ATI Procharger users
Has anyone installed the ATI procharger with 8psi of boost from Exotic Performance Plus, and if so- did anyone have their computer turned by them. Any feedback appreciated.
Old Jan 25, 2008 | 10:11 PM
D-Webz's Avatar
I did the whole setup from them, Bob is a very good guy to work with.If I had to do all over again I wouldnt have changed a thing. I had them tune my computer at first but I went ahead and had it dyno tuned after I payed off my kit and made a lot more power and had better drivability. They did get it pretty close but there is nothing like a real time tuning session.
Old Jan 25, 2008 | 10:20 PM
Is the installation itself easy? I have done all of my work up to this point but I have never touch the internals of an engine.
Old Jan 25, 2008 | 10:24 PM
D-Webz's Avatar
Yeah its not to bad, it takes time. I did it all my self, no help from friends or anything and it took me awhile. There are some glaze overs in the installation guide that can throw you off. But other than that its not bad at all. The worst part for me was figuring out the harmonic balancer because ATI stopped drilling out the hub and the balancer for the supercharger pulley to bolt up to. So you will have to drill it out yourself. I wasnt aware of that at the time but I called Bob and he walked me through it.
Old Jan 25, 2008 | 10:26 PM
Thanks for the help, if you have any pictures or other tips I appreciate all the help.
Old Jan 25, 2008 | 10:29 PM
D-Webz's Avatar
No problem, I dont have any pics but if you have questions will try and help you out just shoot me a PM.
Old Jan 26, 2008 | 04:07 AM
EPP's Avatar
EPP
We now have instructions for drilling the balancer, which will help out quite a bit. Thanks! Bob
Old Jan 26, 2008 | 06:42 AM
kwiksilverz28's Avatar
I have the P1SC system from Bob. The tune he loaded was off, but there a ton of factors, and I have learned more as I go along. It took 4 pulls with adjustments on the dyno to get it right. I just swapped cams and upped the boost, so we'll see how long it takes my guy this time.
Install is a breeze if you have any experience. Instructions are a piece of cake. My only regret is not upgrading to the D1SC when I had the chance for $200. Do it. Just pulley it down to where you want. 7 is my goal right now for longevity with the stock bottom end. Eventually I will replace it, upgrade to D1SC, and then crank it up.
Old Jan 26, 2008 | 06:53 AM
allthrotle's Avatar
^^ How much power did you end up putting down?
Old Jan 26, 2008 | 10:14 AM
02NBMFormula's Avatar
i got my kit and tune from bob, then got it dynotuned. the hardest part of the install was the harmonic balancer, mine just did not want to come off.
Old Jan 26, 2008 | 03:28 PM
Spade's Avatar
I had my whole system installed by them about 4 years ago and have nothing but good things to say about them. I even made a trip there last year to do more business with them, stand up people.
Old Jan 26, 2008 | 10:21 PM
badass99ss's Avatar
The hardest task in my opinion is upgrading the fuel pump, I recommend the trap door method over dropping the rear. The procharger install itself is a breeze.
Old Jan 27, 2008 | 01:41 AM
407hp/406tq with 5#, stock cam, and a nice safe/conservative tune. Just repullied for 6-7#, and swapped to TR's blower cam. Awaiting tune on 2.24.08 I am done modding this bottom end/stock heads. Hopefully I see 450+hp....
Old Jan 27, 2008 | 10:42 AM
allthrotle's Avatar
Thats cool Im curious to see what Im going to put down. Keep us posted with your new numbers.
Old Jan 27, 2008 | 02:49 PM
BLNLS1/RX7's Avatar
They installed my proCharger and dyno tuned it before and after the install.356RWHP and 347 peak torque before install and 563RWHP and 497 peak torque after the install.Every car will show differant results dependant on other modifications.If you decide to go with a ProCharger,there is nobody better than EPP to install and dyno tune your car in North America.
Old Jan 27, 2008 | 08:35 PM
Is the "trap door" method included in EPP's instructions or is that your own way? Any pics or further explination would help. Thanks!!!!!!!!!!
Old Jan 27, 2008 | 08:52 PM
I know the Moser 9inch is the best rearend, I have the stock rearend with 4.11 gears and a Mac cover on for now. I will be upgrading soon. What is everyone running as far as rearends gone with their current setup? Open to all feeback and suggestions
Old Jan 27, 2008 | 08:53 PM
CALL911's Avatar
There's a ton of stuff written on how to do this. This thread has lots of good info and great pics.
http://www.camaroz28.com/forums/show...ight=fuel+pump
Old Jan 27, 2008 | 09:37 PM
helicoil's Avatar
Default rearend
Unless your in Moser's backyard I would suggest buying their housing/axles but not a complete rear end. You can even buy their center section (case) but have someone who knows what they are doing set it up your gears and be sure to get Motive Performance gears. I bought a Moser complete, installed it and it came back to bite me. Rearend was noisy from the get go and only got louder before I took it out and confirmed the gear set-up was incorrectly done after 300 miles. There have been several with the same story, do a search and do your homework.
BTW, they do not have a warranty policy for noise.
Old Jan 27, 2008 | 09:40 PM
helicoil's Avatar
Default ATI balancer
Where can I get a copy of these?
