best 2.5 flex pipe
Old Feb 26, 2008 | 03:38 PM
ls1408cp's Avatar
Default best 2.5 flex pipe
Where is the best place to get it? I heard of people buying some and it neck down inside which I dont want. Someone was saying the inside could come apart in another thread. I need stainless also.
Old Feb 26, 2008 | 04:41 PM
ls1_chevelle's Avatar
racing-solutions.com Ask for Adam. His are SS and great quality.
Old Feb 27, 2008 | 12:12 PM
ls1408cp's Avatar
I was reding not to use the ones with braided inside. Does anyone sell the without the braided stuff in them?
Old Feb 27, 2008 | 12:54 PM
Fireball's Avatar
I have this type...corrugated inside (not the braided stuff on the inside that can come apart)
http://vibrantperformance.com/catalo...f891d0c1cc4fe2
Old Feb 27, 2008 | 01:08 PM
ls1408cp's Avatar
thanks fireball i found those before and couldnt find them again
Old Feb 27, 2008 | 10:46 PM
Not to start anything, But seriously, whens the last time a member on here posted about his flex section blowing up?
Old Feb 28, 2008 | 12:04 AM
ls1408cp's Avatar
not here but on turbo forums a few members had it happen and destroy turbos.
Old Feb 28, 2008 | 05:00 AM
Fireball's Avatar
the stuff with the mesh on the inside can come apart under high heat/pressure conditions and that stuff will tear a turbine a new one
Old Feb 28, 2008 | 08:15 AM
jhilb's Avatar
I just bought a piece of that stuff (with interlock). I was advised to put V bands on the ends and replace it frequently, which I intend to do.
Old Oct 9, 2009 | 10:03 PM
yessir's Avatar
wondering if you could just take the stainless steel weave out of the inside of the flex coupler before it removes itself ?
Old Oct 10, 2009 | 06:54 AM
Fireball's Avatar
why? just buy the ones without the weave inside
Old Oct 10, 2009 | 09:50 AM
RealQuick's Avatar
It takes ~30 seconds to pull it out... pretty easy. I had one customer of mine have the internal braiding expand on the inside and cause a bottle neck.
Old Oct 10, 2009 | 10:36 AM
kbracing96's Avatar
You mean like this?
I just take them out now,
Old Oct 10, 2009 | 11:52 AM
pwrtrip75's Avatar
I'd think the best flex pipe to use is no flex pipe. Ive never used any. Whats the point?
Old Oct 10, 2009 | 04:59 PM
yessir's Avatar
Originally Posted by kbracing96
You mean like this?
did you re use the flex pipe after removal of mesh? if so, how well did it hold up?
Old Oct 10, 2009 | 09:32 PM
RealQuick's Avatar
You mean like this?
Exactly. I remove them like you... they come out easy.
Old Oct 11, 2009 | 01:47 AM
kbracing96's Avatar
Yep, They work great and holding up fine.
Old Oct 11, 2009 | 07:04 PM
yessir's Avatar
yep, they work great and holding up fine.
thanx a million !
