230/236 comp
Old May 24, 2008 | 09:43 PM
bradyfred77's Avatar
Default 230/236 comp
what r u guys thoughts on this cam for a turbo 6.o in a 3100 lb car? 230/236 .592/.602 115+2lsa
Old May 25, 2008 | 08:01 PM
engineermike's Avatar
I think it will work well, depending on the rest of the combo. I'm running a 224/236-114 and I've thought about upgrading to something just like that.
Mike
Old May 25, 2008 | 08:35 PM
trans2000am's Avatar
236/236 .602/.602 114
Old May 25, 2008 | 11:03 PM
thanx guys
Old May 25, 2008 | 11:05 PM
Websy21's Avatar
This is what I'd run over 400ci A comp grind I beleive?
Old May 25, 2008 | 11:29 PM
Old May 25, 2008 | 11:48 PM
TARZAN's Avatar
what heads/intake?
-Will
Old May 26, 2008 | 01:12 AM
Jammer's Avatar
Agreed
Old May 26, 2008 | 08:16 AM
MY99TAWS6's Avatar
Fair amount of duration,normal split..reasonable lift but not crazy and should idle not bad with a 115 and be fairly easy to tune. I think its looks decent. I always say almost any cam can make numbers with turbos so pick a cam that is going to give you what you want in the cam .I wanted reasonable duration, reasonable lift and higher lsa to make tuning easy and give a stocklike idle. I picked up my gt 7 ling cam for cheap and got Yella terra 1.8 rockers to bump it up a bit but still keep it under the 600 lift point. Don't want to be changing out valve springs too often in a fourth gen f body.Not fun!
My cam is still pretty mellow duration wise for a 408. Can always go crazier late but don't think will have to reach my goals.And will have a nice daily driver cam that grandma would like. I don't need bunch of lope in my 99 ta. Old muscle car sure.
Old May 26, 2008 | 11:51 AM
skyhighsami's Avatar
no title here
I have that same cam only .617 lift. VA Speed specd it for me. The car still isnt done but I am turboing it.
Old May 26, 2008 | 01:13 PM
pozesd99''s Avatar
looks like a decent cam
