LSX is ready to be dropped in tomorrow (PICS!)
Here's tomorrows project
And then here's what I got done last night:
Should be able to get the tranny mounted up tomorrow so hopefully Sunday I can start the final F2 mounting/set-up
Great, how much do one of those go for? I like my legs! Why doesn't any one make a protection sheet that can just be bolted in on the interior under the carpet, seems like it would be much easier to install and you never have to touch it again.
Trust me, when you have the shield on top of the tranny, getting to the 2 top bolts will be almost impossible. I don't know what my car makes for HP on the jug (never dyno'ed it on the bottle) but I can tell you I've had 4 bolts in since the car went together, and I haven't had a single problem. If you can get to the top one go for it, but with a motor plate the engine won't "sag" down enough in the back to let you get to the top bolt for ****.
I also moved the bracket about a 1/2" forward after I took those pics. So now I have enough room for about a 70mm belt. I'm going to call procharger this week and get the cog tensioner pulley they have, should fit perfect right where the water pump was.
If you could, then you might be able to use a full width belt, which would be ideal
Actually that pic is before I moved it up more so it sits another 1/2" farther.
you will have to do something to the alternator to make it line up if you do use the vette damper.
I'd love to get to 3200 but I don't understand how guys get to 3000 other than hacking every last peice of anything. I still want the interior to look fairly nice. Last time I weighed it, it was at 3700 with me in it and I've taken out about 200lbs more and added maybe 150lbs with the block & bracket. If I can get it to around 3600 race weight and still look good, I'll be happy. I'll get it scaled once I'm finished.
not that it matters.
