LSX is ready to be dropped in tomorrow (PICS!)
A full battery should have around 14.5 volts. With a meter make sure you have that the starter. When you turn it over are you getting 12 volts to the small wire that goes to the starter?
My brothers truck did the exact same thing last week. It sounded like a bad starter which I replaced. Well I should have did some more checking because it was the positive battery cable. Everything worked like it was suppose to it just couldn't pull enough to actually engage the starter.
Hope this helps and I am sorry if I repeated something someone has already said.
The battery sounds like it's at least partially discharged.
http://en.wikipedia.org/wiki/Lead-acid_battery
# Open-circuit (quiescent) at full charge: 12.6 V to 12.8 V (2.10-2.13V per cell)
# Open-circuit at full discharge: 11.8 V to 12.0 V
# Loaded at full discharge: 10.5 V.
No battery is going to be over 13.0V
It should read around 12.5V with the multimeter at rest. If it's dropping down to 11.X with JUST the key in the KOEO position, the battery needs a trickle charge for sure.
Just for kicks, any battery that has sat for a year+, is suspect for replacement.
Trickle charge the battery. Then you can just go to autozone if you have one local, and they will load test the battery free of charge. Just make sure you get an employee that knows what the hell he's doing. Becuase as we all know, half of them are about as smart as a brick.
That eliminates all your guess work. If it's junk, buy a new one and then you KNOW your all set on that front.
If this ends up not fixing your problem, you need to look to the starter.
I just stuck a MM on my optima and it read 12.2 volts. Running, I would expect 13.5-14.5 VDC
I would just make sure you have a ground on each side of the block then check the one for the harness.
Also did you leave the meter on the bat as you were cranking it to se if the starter is just drawing to much current
Don't you know anyone with a stock car that can stop by that you can look at, just get under it and look and see hwo the **** is hooked up?
if you had that much smoke and actually melted the battery, you're gonna have a whole bunch of other problems, wires get that hot believe me there's alot of stuff that's now gonna e compromised... might not whoe up right away either which makes it even worse.
Good luck with this one.
Does it look like the terminals on the starter are reversed? I don't get how they could be, the hot has a tab that slides into a slot on the hot side, at least that's what I thought it was there for
