LSX is ready to be dropped in tomorrow (PICS!)
put your finger on one of the injectors while cranking the engine and feel for a pulse. at least that will start narrowing down your problems.
my bet , blown fuse!
Does anyone know which sensors will cause the car to get no spark? The crank sensor is the only one I know but I'm not sure if that's it. First I'm going to check for spark. If there is no spark then I can go through all the fusses, relays and then I have to start going through sensors. If there is spark, then I need to look at the fuel side of things.
I did read that you may need to switch the wires on the sensor not sure witch wires but I know it was the crank sensor
This morning I did make some progress. I'm getting spark and it just so happened it poped the first time while I had my girl holding the plug wire with the exposed plug and scared the **** out of her, poor girl, I feel bad having her help me, shes the best
Anyway, after that I put the plug wire back on the plug in the head and tried it a few more times. First was a couple random bangs/pops then as I tried a couple more times I started to get a studder, like it was almost trying to start but I didn't hear any exhaust. I'm wondering if it just takes turning it over some more to get the computer to relearn the new set-up and figure out the timing. Is it pretty normal to have to try starting it a bunch with a new engine? Either that or the sensors are still in question but I didn't think I would get spark if that was the case. It sucks cause I'm scared to death to keep turning it over after the little fire insidence. The Best V8 Stories One Small Block at Time
what kinda tune do you have in the ECU? i would imagine even with a decent mail-order, it would take some time for the engine to actually fire. i mean, if all your sensors work, fuel and air is ample, and you have spark...then the only thing affecting your ability to fire would be timing, which is set by the computer.
the whole not enough air going to the engine sounds reasonable. easiest way to check is to have the belt on and give it a try. if that doesn't work change the cam sensor wires just to make sure , then change both cam and crank sensors, if that doesn't work ( you would atleast have two spare sensors) i would be suspesious of the pcm.
