Up the boost?
Its at the shop that tuned it so they can retune easily and I plan to have them retorque the heads since it hasn't been done yet.
The engine is all forged, crower rods, mahle pistons, 9:1 compression with all ARP studs and bolts. Fuel system is a sumped tank, A1000 pump, and all aeromotive lines, rails, regulators and 60# injectors. There is no particular reason I feel the need for more power other than the car is in the shop anyway, and I am curious to see where the safe limit is and what the car will make.
comments please, thanks
http://www.exoticperformanceplus.com/dyno.php
Maybe the clutch was slipping when you had it tuned? Bob
I have the smallest pulley combo available on my Z28, and on a very cold day at sea level my D1SC only saw 15#'s of boost (granted I only have a ported LT1 intake and ported AFR 180 heads and a very large cam), but even if I had the ideal setup, I doubt I would see more than 2-3#'s more.
To determine the impeller speed, the following formula is used:
Maximum impeller speed = crankshaft pulley diameter (N1) divided by supercharger pulley diameter (N2),
multiplied by the step-up ratio (4.10 for the P-series/D series - 5.40 for the F series), multiplied by engine rpm at redline.
Your crankshaft diameter is 7.65, max rpm of the D-1SC is 62,000 rpm.
A 3.40 will put you at 62,730 at 6800 which would be just fine. Bob
Well they guy I am takin about has stock casting heads . I guess the aftermartket head with the thick decks is the ticket to keeping the heads down .
Not to start getting off topic, but generally speaking, a stock high CR engine with non-forged internals + boost will =
on your face. hah
