building a 1300-1500hp turbo LSx ?'s
Old 07-01-2008, 01:31 PM
OutlawZ's Avatar
Default building a 1300-1500hp turbo LSx ?'s
Hey guys I'm gonna be coming up on some cash in the next few months and I want to start researching my next project. I might even pick up a roller to do it with but if not I'll build it on a stand and put it in my 95 that is already setup chassiswise to run 8.50...
Here's my question for you FI guru's.... Starting with a bare LSx block what combo of cubic inches and parts would make the best all around turbo setup to make between 1300-1600hp to reliably run deep in the 8's??
I was thinking a single 91mm-94mm turbo to keep the amount of piping required down to a minimum. Something along the lines of what Wormboy used to run..... But i'm also open to the idea of big twins as well....
And lastly what cubic inch range should I be looking at for a fast spooling nasty 10% street, 90% strip car? I was thinking somewhere in the 370-390 range but again i'm clueless when it comes to turbo stuff....
So if you had about 12-15 grand to build a motor what would you put together. I don't know if i could get the turbo and intercooler stuff for under that 15 large but I would hope I could. If not i'd just put the motor together with it and buy the intercooler/turbo seperately... thanks guys...
Old 07-01-2008, 01:37 PM
HUNTER02SS's Avatar
Alot of different options outhere for sure. Just make sure you keep it simple. Nothing out of the ordinary has to be done to make that kind of power.
All my motor stuff is out of the box bolt on. Just save some cash for when its completed to make repairs.
I would go with 370-377ci. with a big single. Get a good fuel system also.
The following users liked this post:
vff_jeff (09-23-2019)
Old 07-01-2008, 01:49 PM
VENGEANCE's Avatar
408 with a 106. You can make that power with smaller cubes and smaller turbo, but if youre going to spend the cash, Id just go ahead and go bigger.
Old 07-01-2008, 02:01 PM
1INSANEGTO's Avatar
408ci with a compression of 12.5:1
Single 106MM
On Achollllll....
Old 07-01-2008, 02:30 PM
LS1TECH Sponsor
DrTurbo's Avatar
Single 94mm will easily get you those times and all you need is a 370ci engine, or maybe something in the 390ci range as well for a little quicker spool.
Old 07-01-2008, 03:26 PM
OutlawZ's Avatar
My fuel system right now consists of a Nasty sumped tank, Weldon 600A (which will be swapped out soon for a 2345 Weldon) twin fuel labs filters, 10AN supply line up to the y-block, then split to two 8AN lines to the rails. 6AN return back to the tank with a fuellabs regulator. I'll be dumping my current injectors for 160lb/hr units in a few months.... So I THINK i'll be good there and just be able to swap everything over....
So i'm getting that somewhere between 390 ci and 408 ci with a 94-106mm single would be the deal huh???
What are the bore and stroke combos using an LSx block to reach both of these displacement #'s????? I want to start pricing parts.
I'm guessing some diamond pistons, lunati crank, and oliver rods would be fine??? Also would I need 6 bolt heads????
Old 07-01-2008, 03:35 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,118 Likes on 732 Posts
Sounds like you are on the right path.
Old 07-01-2008, 03:44 PM
BoostnTBSS's Avatar
I see alot of the big singles have more trouble spooling.. i would go the 408+ci and twin 76's and push some boost thru her like 25psi+
Old 07-01-2008, 03:56 PM
OutlawZ's Avatar
anybody got pics of packaging under the hood with twin 76's......
Cause I just talked to my engine builder and he's drooling over the idea as well....
408 with two 76mm hairdryers.... hmmmmmmmmmmm
Old 07-01-2008, 04:13 PM
BoostnTBSS's Avatar
Look at hunters setup!!! def a cool setup and sharp but if you go the a2w ic in the back set route mount them way out front!!!
Old 07-01-2008, 04:37 PM
venom ws7's Avatar
Search Tiago his setup have Twin 76mm they look sick
Good luck with the build man 408ci with twins will be very mean.
Old 07-01-2008, 05:00 PM
OutlawZ's Avatar
appreciate it guys......
how much you think this will all cost???? Keep in mind I already have FAST XFI standalone, fuel system is done, car has an ATI TH400 with all the bells and whistles and the entire suspension is done as well as safety as well...
All I need is the motor, motor plate, turbo's, intercooler, and piping has to be fabricated.... Oh and the blowoffs and wastegates as well....
I'm thinking what like 15-18K?????
HUNTER02SS's Avatar
Here is a vid of a LS2 with a 94mm on the 8th. mile. No spooling issue's!
http://www.youtube.com/watch?v=0cB-sBbSE6Q
Old 07-01-2008, 05:01 PM
HUNTER02SS's Avatar
What do you need a motor plate for?
Old 07-01-2008, 05:14 PM
LS1TECH Sponsor
DrTurbo's Avatar
Looks like the boost is turned down. A 94mm is a solid 4.9-5.0 turbo@140+ if the track is working. Also that video says 98mm....hmm. Either way their is more left in that setup.
Old 07-01-2008, 05:18 PM
OutlawZ's Avatar
My current setup is an LT1 nitrous motor... I went 10.60 on the motor and i'm getting ready to spray the hell out of it and shoot for 8.90's.... but an LS based turbo deal is in my future. My k-member has LT1 motor mounts... Price to buy a new k-mbr with LS1 mounts? like 500 bucks..... cut off the current mounts and use a motor plate.... like 150-200 bucks....
I could swap k-members but it would be less expensive to just motor plate it and keep my current LT style k-member....
Old 07-01-2008, 05:20 PM
Worm Boy's Avatar
Here is a twin 67mm turbo car we just fired up for the first time on saturday. Outlawz, shoot me a pm if you need pricing on different setups.
Old 07-01-2008, 05:23 PM
HUNTER02SS's Avatar
You are correct. They just got done with the new motor and its a 434ci. LSX Block with ETP 6 bolt heads. They are currently working on some tuning for the new motor. 94 or 98, I can't tell, they are all huge!
Old 07-01-2008, 05:27 PM
Reject's Avatar
that's a pretty tricked out engine!
Old 07-01-2008, 06:08 PM
slick1851's Avatar
I wonder how twin 106s would be...........!
Quick Reply: building a 1300-1500hp turbo LSx ?'s
