42 pound green tops? 600whp??
got a set of ford green top 42 pound injectors.. I am going to up the boost next weekend on the dyno and retune. shooting for 650whp..
will 42 pound injectors at the ls1 fuel pressure support that power? they should be more like 49pounders with the pressure i believe.. but is 650whp doable?
i have no idea what my RWHP is because i havent been on a dyno in a very long time and have changed my combination so much.But i am naturally aspirated not boosted,and the last time i ran the quarter i think it was 10.93 at 126 or 123 maybe? that was with the duty cycle actually at 106 percent. By the way the green tops so far have had the best idle and part throttle drivability.Maybe i should just keep my trap shut, just dont want you to harm your engine.
I understand, and after talking to my builder we decided that 600whp is the target.. sorry guys.. that being said 42 pound fords at 60psi puts it close to 50 pound injectors.. I should be good with these green tops at this power level I believe. he said he is expecting 580-610whp but doubtful it will be more than that range. so i guess I misunderstood at first.. ford 42's and a walbro do well ya all think?
Have since installed 60# Siemens Deka injectors and they have given me more than enough room to finish tuning the car.
I will be using the stock lines, you should be alright with using stock lines as well.
