Fuel pumps and hobbs switch??????
People who run a hobbs switch for there secondary fuel pumps why is a relay used?
Just curious why would you not just run a direct feed from alternator to hobbs switch and then to the fuel pump and add an inline fuse? The pump would not get power till the hobbs switch activated.. Just dont understand the relay in this case...
(edit)Here is the hobbs switch that I run... Doesnt give an amp number but it looks pretty stout..
http://napaautoparts.com/Search/Resu...word&Nty=1&N=0
Like I was saying if you use the power side of the relay on the hobbs (meaning there is power on one side of the hobs switch) what is the purpose of the relay? When I look at this diagram in this thread appears to be on the hot side... https://ls1tech.com/forums/fueling-i...g-diagram.html
(Another) Mike
They due this for several reasons. One you dont need heavy wires to run up to you dash switches. (allowing for smaller switches,alot less wire, or weight)
Lower amp switches are cheaper, lighter. so weather its a head light switch, interior dimmer or a hobbs switch you dont need to run 15 amps threw it. Also makes them last longer in my experience. Hope this help. The question I have is im running a bypass regulator ( obviously return style system). Why do guys run the second pump on a hobbs switch? why not just let it go back to the tank. Sorry for the hi-jack.
