Whats the most RWHP put down by a triple 255 pump set-up
I know theres multiple combos out there and know Mighty mouse had or still is running this set-up but wondering if its going to work for me. Reason for putting it in this section is because its on a Turbo car and this is section seems to see the most traffic.
What is your set up going to be and expected power level? Fuel type? The triple pumps will usually support more power then most can use. A local car put down 1100rwhp with triple pumps on E85, with room to grow.
Yea David runs three 255's. I have his buddy Jarrod's old car and it uses two 255's in the same set-up without the dual in-tanks and one inline, mine has one in-tank and one inline. What are you looking to make? My dual 255 set-up with 60lb. injectors should support 650-700 and that's limited by the injectors and stock rails.
