Is there a 75 lb/hr high impedance injector?
I keep hearing rumors of a new 75lb/hr High-Z injector, but haven't been able to find anything concrete.
Sucks if it is true cause I just got a set of Mototon 60s!
Anyone else heard about this?
used to be some 'mustang' company that would take other xx#/hr high z injectors and 'port' them.. i have to figure this is what injectors are being talked about as they are being mentioned in limited quantity and far as i know that one mustang shop no longer does this because they were getting customer complaints.. but i could be completely wrong too
fwiw from the flowrates i've seen mentioned i can't see where they are flowing noticeably more than my mototron 60's. you should be able to do over 800rw on them.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
With the 408 and the turbos I am hoping to be over 800hp
But, in all honesty, after the car is back up and running I am going to make my decision on FAST, DFI, Big Stuff III, or AEM.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
LS1Tech Co-Founder
The big question is not what is available but how well do they work with a stock computer.
I'm running a FAST with low imped 83 lb Siemens.
My concern with big hi imped injectors is the off idle transition, they might be hella fat at idle and not transition well, anyone got a set of 60's or 75's at 14:1 at idle without adding large amounts of timing?
