255lph fuel pump and harness upgrade kit available!!!
Old 10-03-2006, 11:35 AM
Zach@Texas-Speed's Avatar
Default 255lph fuel pump and harness upgrade kit available!!!
We have put together a fuel upgrade package that will allow you to increase your F-body fueling capacity to give you even more fuel than just a basic 255lph swap. This kit will include a Walbro 255lph Fuel Pump and a Casper Wiring Harness that will completely replace your stock harness and increase voltage to the fuel pump. The harness pulls voltage directly from the alternator and is transfered directly to the pump assembly on the tank. This kit will give you even more power capability than just swapping to a walbro in tank pump. The wiring harness also has an adapter fitted to make use of an inline fuel pump if a secondary fuel pump is needed. We are introducing the kit at $199.99 plus shipping, regular price will be $239.99. Below is a picture of everything included. If anyone has any questions let me know!!
Old 10-03-2006, 12:22 PM
getusum's Avatar
Is it available with just the harness - the fuel pump? I just installed a new pump...
Old 10-03-2006, 01:09 PM
brad8266's Avatar
Nice kit
Old 10-03-2006, 01:35 PM
The harness alone will be $89.99 plus shipping
Old 10-03-2006, 02:12 PM
ICRAZY6's Avatar
how long will the sale run???
Old 10-03-2006, 02:55 PM
It should go for a week or two
Old 10-03-2006, 07:17 PM
mikep2002's Avatar
It sounds identical to the ractronics kit. I has to have better customer though. Cant get any worse than ractronics customer service.
Old 10-04-2006, 02:14 PM
Stroker2112's Avatar
Zach,
Can I get your item # 27-GM722-2 (Walbro 255 for GM truck) with this harness for the sale price?...
Stroker2112
408ci iron/forged, Torquer2, CnC'd & milled 243s, Diamond Pistons, True dual LTs, K&N Air, 44lb injectors, stock intake & TB(upgrading soon!).
Old 10-04-2006, 03:44 PM
Originally Posted by Stroker2112
Zach,
Stroker2112
Sure thing!! Give me a call and I'll get you set up.
Zach
Old 10-04-2006, 04:21 PM
STALL UP's Avatar
EDIT.
If you spam another vendor's ad here, you will be banned
-Admin
Old 10-04-2006, 05:59 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
sound like a good kit what is the difference between that pump and the one with the racetronix kit?
Old 10-04-2006, 08:33 PM
speedyss's Avatar
is the purpose of the increase in voltage just to get more out of the fuel pump, for a cheaper price? verses get the aeromotive stuff with the fuel pump voltage controler? also by increasing the voltage to the pump does that change the lifespan of the pump?
Old 10-05-2006, 11:26 AM
STALL UP's Avatar
Originally Posted by STALL UP
EDIT.
-Admin
Thanks, you have a great day.
Old 10-05-2006, 11:35 AM
With this harness it should not reduce the life of the pump. This is just a direct way to get power to the pump, it doesnt overwork the pump, it just makes better use of the power available to the pump through larger gauge wire and a direct feed to a power source.
Old 10-05-2006, 01:42 PM
Zach,
Is there a discount or promo code I can use to order this online?...Can you PM it to me?..thanks
Stroker2112
Old 10-05-2006, 01:57 PM
There isnt a promo code, but if you order it online it will get discounted before charged, or your more than welcome to give me a call and order over the phone. We have these in stock and ready to go!
Old 10-05-2006, 04:23 PM
longrange4u's Avatar
Zach... when you gonna produce a dual intank setup? Please say it will be less than 550$
Old 10-05-2006, 06:48 PM
00ls1's Avatar
Old 10-09-2006, 12:07 AM
TransAm6383's Avatar
available for the LT1??
Old 10-10-2006, 07:51 AM
PAGregSS's Avatar
It looks like my fuel pump is on it's way out and I'm trying to decide between this or the Racetronix setup. Zach, could you please shoot me a PM and give me an idea of the differences, if any. I have a '98 with the metal tank. Not sure if that has any bearing. I'd like to get this ordered today or tomorrow. Thanks.
