Old May 26, 2016, 04:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
How to run your LS1 on E85
Old Nov 15, 2009 | 11:49 AM
  #441
tjZ06's Avatar
Originally Posted by ericwilloughby
I think all of "our" lines are nylon and thus ok. I don't see how the strainer/sock could ever be a choke point.
I guess on the Evos the sock breaks down and actually clogs up the pump. I guess nobody has run into that on our cars?
-TJ
Old Nov 15, 2009 | 04:19 PM
  #442
ericwilloughby's Avatar
Nope, been on E-85 years. Never had a problem. Tanks been examined 3 times.
Old Nov 16, 2009 | 08:03 AM
  #443
nicholas1752's Avatar
Great info Thanks
Old Dec 13, 2009 | 08:38 AM
  #444
Jeff Smith's Avatar
Subscribing..Good inform....
Old Dec 22, 2009 | 12:33 AM
  #445
oscareltemblo's Avatar
I have a suggestion could you guys running good e85 tunes post your tunes files for comparing info it would help alot.
Old Feb 21, 2010 | 11:18 PM
  #446
fucter's Avatar
any tips on how to do this with a diablosport predator?
Old Feb 23, 2010 | 05:18 AM
  #447
I used a Predator for a year on E-85. If I recall, 25% richer on the injector slope and add 15% timing across the whole range.
Old Feb 27, 2010 | 09:46 AM
  #448
fucter's Avatar
awesome, thanks for the reply
Old Mar 1, 2010 | 09:11 PM
  #449
atli126's Avatar
great info, should be rowdy in my lsx rx7
Old Mar 3, 2010 | 08:51 AM
  #450
Pony Exp.305's Avatar
I am new this forum and will read thru +20 pages in this forum.
Subscribing
Old Mar 11, 2010 | 11:28 PM
  #451
99T/AVert's Avatar
Wonderful info! I would love to run some e85 but sadly my area does not have even one gas stating that offers it. The park and recreation department for the city has it but only for their vehicles
Old Mar 26, 2010 | 07:05 PM
  #452
fucter's Avatar
Made the switch, still in the process of tuning it
Old Mar 26, 2010 | 07:36 PM
  #453
Mia's Avatar
Mia
what does the cap say?
Old Mar 26, 2010 | 07:37 PM
  #454
fucter's Avatar
ethanol/gasoline or something like that
just an easy way to remind me not to fill up with gas
Old Mar 26, 2010 | 07:44 PM
  #455
Mia's Avatar
Mia
what did you get the cap from?
Old Mar 26, 2010 | 07:50 PM
  #456
fucter's Avatar
theres some guy on ebay selling a bunch of them
they fit camaros but the cap is a little harder to get on tight
search ebay for "e85 gm cap"
seems like they have GM part number 15896222
Old Jun 16, 2010 | 06:54 PM
  #457
ttbestas's Avatar
how to modify transient fuel tables in hp tuners when running e85? thanks
Old Jun 21, 2010 | 01:37 PM
  #458
JustAGoat's Avatar
Ok with the mods in my sig how much of a gain do you think could be had? (if i would do this i would put something over a 42 lb injector and a ls6 intake and ported TB)
Would the injectors all i have to do up front??
Also I live about 2 hours away from where i would tune it so how would i go about this, should i MT my tank at home then drive all the way down on E85 to make sure all the Regular fuel is out or what should i do?
Old Jun 21, 2010 | 09:50 PM
  #459
Expect 25 hp 30 tq bump. If you tune for it. I used the stock 32# injectors with my ls2. Your tuner will let you know when they are maxed.
On the fuel. Run the gas as low as you dare. Put 2-3 gallons of E-85 in it and run it as low as you dare again. Then fill it up and drive to the tuner. It will run on E-85 until you can get it tuned. Ignore the CEL.
I wouldn't waste $500 on a tune just for the switch. Buy a flash tuner and do it yourself. Then you'll be able to switch between the 2 fuel types.
Old Jun 22, 2010 | 12:07 PM
  #460
JustAGoat's Avatar
Well the thing is i know the tune right now isn't right it's for sure running rich right now, so i was going to go and tune it anyway...
When you say a flash tune u mean hp tuners?? Is there any other tuner out there that doesn't need a laptop?? I just want the most out of my tune anyways and my motor setup won't change for 2 or 3 years from now while i do my full suspension and rear end...
There are plenty of E85 stations around my area and i when i drive it to work there are 2 gas stations that offer it.
