Need help with fuel pressure
Set that switch in the 40s somewhere.Also, if you were previously tuned, you will need to have your WOT touched back up, since the PCM is blind to fuel pressure. Your trims at part throttle will be significantly negative now too.
I'm trying a few things before going to a fuel rail mounted regulator with a Racetronix pump (my car is stock internally) and see if I can help it some.
I think it may just be an inherent problem with running the regulator in the tank. The other guys have you covered on the FPSS...what you are seeing for a pressure drop is about what I'm seeing (I idle at 58 psi, and drop to 51-52 psi under WOT).
Also excuse my ignorance but the car was being tuned on the dyno when the car was being sprayed for the first time, by WOT touched back up you mean?
I don't remember how the fps switch is adjusted, its been a while. If you do a search it was covered before or if you have your instructions that came with it that will be helpful also.
I'm hoping it was just my kinked plastic line going from the tank to the filter...it has been that way since the last time I changed the fuel filter, but I got most of the kink out. The kink is now worse than ever, so that line has to go.
I'd like to get my car back on the road since it has been on jack stands for at least 4 months now
With the snow, though, that prospect doesn't look good. Re'
ok guys I have been fighting a loss in fuel pressure in my car. At WOT anything past 5800RPM I lose 18PSI of pressure.
So far I have hot wired the pump power and ground side so I know it is getting 14.8 volts. I have a Walbro 255HP pump with -6 lines for the supply. The tanks is over 1/2 full.
What could be the trouble here guys I have tried everything and it still just falls off at the top end. I think I have a bad pump thats they only thing I can see. Anyone else have something to add here. Oh it is doing this on the Dyno, and driving!
here is the pump before it went in the tank
really, I mean it works at idle and all the way up to 5800 then it drops off.
I was thinking of steping it up to this pump.
Bosch 040
The reg is like this one.
The filter is this size but not this one.
https://ls1tech.com/forums/fueling-injection/832298-fuel-pressure-drop-need-help.html
You should be good for approx 550rwhp on 1 pump. If you need more, I can fix you up with a twin intank setup that will take you to the 1000+rwhp range.
Happy Holidays
The dirt would have been caught by the filter before it got to the regulator.
Also the press would be probably be low at idle if something was in the regulator.
What type of tank & lines are you running in that vehicle? Maybe I can help diagnose your problems. Is your tank or cap vented?
I had an old '68 Camaro once with the wrong gas cap that sucked the tank bottom up 2" after running it hard. It would lay over on the top end & after trying to diagnose it, I pulled the cap off & the tank popped back into position.
Some cars had vented caps, some vented tanks & some have 1 way check valves that allow air in, but not out. It depends on your application.
A common problem is when people eliminate the tank evap lines & leave no means for venting. I'm not saying that is the problem but it should be ruled out before you start buying pumps & regulators.
