Fuel Pressure drops to zero after start
I can hear the pump prime when turning the key to on. Its holds about 10psi before I start it. Soon as I start the car the fuel pressure drops to 0.
Any ideas?
If you're going to drop the tank, get a manual and follow it. I did it today. 3 1/2 hours. There are write ups on the web. I went to the library and printed out the instructions. They were close but not exactly right. I dropped the muffler and left it under the car. Covered it with an old blanket and used it for a pillow. I'm not looking forward to putting it back in
Al
2002 Z28 M6
this is the way I did it. good luck...
I have dropped the tank before and put it back in, I just never have had a full tank of gas in it before I did dropped it.
That is I wanted to find out a easy way to siphon the tank.
Thanks agin fellas.
When I initially did my dual in tank Walbro system, I had an issue with the fuel pump always popping off the rubber fuel line that attached itself to the fuel pump. It would pretty much do the same thing you are describing. I would see the fuel pressure drop to about 0. The rubber hose would never stay on no matter how tight I clamped it on the pump, and the tighter I clamped it, the more it destroyed the hose. After having to deal with this at least a dozen times, I ended up going with a steel braded line instead of the rubber, and I haven't had any issues with it since. I could still hear the pump trying to prime, but no fuel pressure. This possibly could be what you are experiencing. Get the fuel tank opened up and take a look. I would bet that the issue you are experiencing is coming from there.
If its not, there is probably a fuel leak somewhere. Check all your fuel lines and hoses, including the fuel pressure regulator and injectors.
Good luck. Let us know what happens.
I have a serious bug to work out.
I cut a fuel door in rear of the car so that I can see the pump working and acesses it quicker.
All of a sudden the pump has started working but there is no fuel pressure. I am going to check the guage ground tommorow to see if that is the issue. Last time the car would go all the way lean and then shut off. I am going to also log the injectors pids too see if they may be causing the problem.
Bob it is a walbro
Uhhh.... No they don't.
