race gas vs. o2 sensor life.
how do the guys with race only cars deal with this? constantly swapping in new sensors or always splitting with some unleaded to keep them alive? i imagine they do not last long at all under say 116 octane. whats the word?
Thanks.
Thanks.
There was a post a few months ago about some new NGK o2 sensors that lasted a lot longer using leaded gas, might not be a bad idea to find it and bring it to the top.
Scott
Scott
Yeah, I am pretty sure that is what people have been doing.
Personally, I tune for 101 octane unleaded for my race programs...If I want more octane then that then I toss in a little Xylene or Toulene.
I think that a lot of the guys that run leaded gas eventually move to FAST or DFI and run without o2 sensors everywhere but the dyno.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I'm going to tune my car on 93 octane, but most likely throw in 100 when it goes to the track or if I'm going to have an aggressive night w/it...
Just to be on the safe side....
so without these ngk sensors people just ran sensors through the car? thats terribly expensive.
And no there not that expensive.
do a search in this section, Prostock John and I have a topic about them.
LS1Tech Co-Founder
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I never tried the Densos, but the price was fairly cheap.
I went to a FAST system since I am going to run straight C16 (VP 117 for FI motors) for a while on the car.
Well the car wasn't having any Air fuel problems when it was hitting higher than 12psi, that was with 93 in the tank.....
It was before when my fuel wasnt keeping up, but now that problem is solved....
Nope, the wideband o2s will foul out as well on leaded gas...and they are much more expensive to replace.
People usually tune at the dyno with the wideband in the car and then pull it out and run without them everywhere else.
I know a guy with a car that races in the local PSCA series out here in CA and he changes the wideband after every 10-15 passes.
Scott
Scott
Another alternative for high octane is to visit your local airport. Their gas is 100+ (I think most use 101) and it is unleaded.
While you're there you can race a plane or two down the runway
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
FASST, Av-gas is NOT unleaded. It is low-lead...which is to say, still quite leaded. Also, your mixture will be thrown off because it has a very low specific gravity.
About the WB O2 sensors. It is true that they will eventually foul from leaded fuel but they will last a long while...especially if the car is a track only car (and if it isn't, then why do you need that much octane!) Ask a dyno operator about WBs and leaded fuel.
I think alot of you may not know what kind of unleaded fuels are available. Check out VPs website at www.vpracingfuels.com You'll notice that unleaded goes all the way up to 106 motor octane. 106 motor octane will carry you a long way. It's ALOT better than AV-gas!
Not sure John. I have a WB o2 setup and after about 25 passes (15 track 10 dyno runs) in my buddies mustang the o2 sensor is junk.
The guy that I was referring to who changes them after 10-15 passes is running low 8s @ 176 with a SBF and a big turbo.
I guess your mileage may very, but most of the big dogs that I have seen pull the o2s after tuning sessions and race without them.
