How much hp does a 9in Ford eat up ?
How much HP am I a going to loose compared to a 8.8 or a 12 bolt? Also say on a 11.5 second car how much difference in timeslips?
Thank You,
Bart
Thank You,
Bart
I am just trying to figure how much I am going to loose with my steel drive shaft and a 9 inch. If it is a signifigant loss then I will see what I can do inside the F**d 9 inch to mabe get a few ponies back.
Knowlede is power.
Knowlede is power.
I am curious as well, I have the same set up (9" steel ds) and I went with a lightened ring gear and a lightened locker to make up for a little bit. It is going in the car on friday. I am not too worried about it though cause the nine " will definately handle the power.
Brad
Brad
According to this article, the 9" uses 2-3% more power than a 12 bolt.
http://www.chevyhiperformance.com/te...les/0304_nine/
So if you were making 400rwhp with a 12 bolt, that would be a 8-12rwhp loss. I'm sure its more when compared to a 10 bolt. Seams a little high to me but just going with what the article states. I'm kind of wishing I went with a 9" than my Moser 12 bolt. Much cheaper and stronger.
with a 9" ,you can build extra 3rd members with different gears and change them at the track in about 45 mins. I have a 9" in my S10 and I love it ! the extra weight helps out with traction too.
Just installed mine last night. Going to put the finishing touches on her in a few minutes. I have been planning on building an aluminum 3rd member with a spool and a little less gear for the spray just for the track.
How is your Moser holding up? Any issues with breakage or noise?
Originally Posted by 1ScrudeDude
The 9" is cheaper? I looked at a few vendors, and the 9" is more $. True, it is much stronger. Also, won't you have to inop your ABS?
