Tried to swap posi unit. Why didn't it fit?
My posi isn't working but I have a parts car and the posi in it was working great, so decided to switch them out. My car has 3.23 and parts car has a 2.73, so I didn't want the whole rear end, just the posi carrier piece. I knew I would have to bolt my ring gear on the other carrier to install it, but I figured it would go right in. When I did, I found out the carriers are different and I actually need about a 1/4" spacer for the ring gear to move over so it will line up with the pinion.
Any one else have this problem? Do they make a spacer?
Thanks guys. So, to get the good posi in there, I'd have to change the pinion gear too? Which means my choices are 2.73 with posi or 3.23 peg leg? Which would you prefer?
I dont want to sound like a jerk but the questions you have I think your going to have bad mess soon. setting up gears isnt for most techs. very few can setup gears correctly.
your going to need to set pinion depth and backlash all to spec and adjust based on pattern its the hard truth
similar,but opposite,to a very recent thread
that one to put 3series gears into a 2series carrier car
https://ls1tech.com/forums/gears-axl...t-problem.html
this one to put a 2series carrier into a 3series car and retain the 3series gearset.
I'm not going to pretend to know alot about rear ends. I wouldn't change out the pinion/ring set on my own, just like I didn't try to switch the carriers out on my own. Luckily I have experienced racing techs in the family that can help, but none of us really thought about the possibility of 2 different carriers.
So here's another question: Can you rebuild the differential or swap the internals of these 2 carriers or is that more trouble than it's worth?
