Ive been following that a little. He seems just as fresh as I am at this. I figured out that they make a housing end that accepts a Ford 3.15 bearing with a small gm car bolt pattern such as a 12 bolt or 7.5 and I can use my stock brakes that way. So I ordered the tube ends today and will hopefully be narrowing the housing this week and then I can get started on installing the brackets and finishing up the housing. Then on to building the third member and buying axles.
