Amsoil 75W90 Gear Oil question
I have some Amsoil synthetic severe gear 75W90 sitting in my garage, would that be alright to put in my shitty 10bolts for a oil change, i have the GM limited slip additive also. Just wanted to ask, because i dont know if putting the synthetic in will be too smooth for the rear, granted i would be adding the limited slip.......... so anyone out there with some comments please let me know, and the reasoning why
If you rear end can run synthetic I do add bottle addictive anyway, even the gear oil say it already have addictive in it.
and if you rear end run just regular dino gear oil, I do still add bottle of addictive to it too.
Good stuff man! yea....cant wait to get back to the states so i can do my Heads/cam/102 intake i have all the parts just sitting here in my garage but no tuners around here that i trust with F-bodys.......im gonna swap the oil this weekend and see what the result is....
Per Amsoil the Severe Gear 75W90 has the LS additive already in it so you do not need an additive.
AMSOIL SEVERE GEAR® is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifier additive.
http://www.amsoil.com/storefront/ada.aspx
This is the oil that I am going to run in my 9" ford. Here is a comparison chart of all the gears oils. They test all the oils and Amsoil comes out with the best grade. All the proof I need.
http://www.modernoils.com/g2457GearOilWhitePaper.pdf
somebody has done there research, haha thanks bro, this i already know i was just unsure with my sweet 10 bolt. i try and let you guys know what happens, takin it to get a alignement tomorrow after redoing my suspension, then i will put the new gear oil and cover on and see how the band aid keeps my grenade intact
