Painting rearend
I just ordered a Dana 60 ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
and I plan on painting it black when it gets here in a few weeks. I have a somewhat stupid question. When painting it what areas are good to stay clear of/not get paint on? I tried searching and I cant really find a good answer. Anyone paint their dana with POR-15? Thanks.
I painted my s60 2 weeks ago semi gloss black por15. I got the starter kit since it has metal ready and marine clean to prep it then also got an extra pint. brushed it on and looks great.
![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
coverage on por-15 is roughly 30-40 square feet per pint. 60/80 on quart and that is pretty conservative......good luck and have a blessed weekend.....
Captain jim
Tip: Get the rearend very clean of oils because it will fish-eye if you don't.
http://www.flickr.com/photos/1835930...7623345499537/
I cleaned with soap and water, and used POR's metal prep which is a zinc compound that is supposed to etch new metal. I had a couple of very small fisheye problems on the cover, but that was about it.
FYI the rust on the housing formed in about 10 minutes as i was letting it dry. It wasnt present at the time the rear arrived. Definately need to paint, or it will be a rusted mess at first wash.
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111040.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111041.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111041a.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111041b.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111041c.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111602b.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111602a.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111602.jpg)
![](http://i47.photobucket.com/albums/f183/deelong4002/Rear%20swap/0305111604.jpg)
Just tried to be careful. I may have got a couple of dots on there, but i'll just hit it with a wire brush before i install the brakes.
Wear gloves, and long sleeves. I have that **** dotted on my arm, and it does not come off unless you scrub it with something abrasive.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
One last thing to consider is temperature!! Make sure the shop or garage is above 50 degrees..........good luck.....the por 15 will make you a very happy camper.have a truly blessed week....captain jim
For those spray painting I just did my 9" housing yesterday. I have a BMR black hammertone kmember and lca's and drop brackets. Rustoleum has a spray paint you can get right at wal mart also called black hammertone. It match's perfectly. Texture and all.
