How hard to remove differential?
Just like the title says, how hard is it to remove the differential? I have 4.10 motive gears on the way and i have a reputable shop that says they'd swap em for $150 but they only want the housing to do it cuz they don't have a lift. They mainly build engines but can do gear swaps. I have a buddy who can do it for $250-300 but I'd like to have a shop do it so they'll cover it if they screw it up. I doubt my buddy would lol. what would u guys do? if it's not much work I'll pull the diff and take it up there. Its just to holde over until winter until i can buy a new rear end. I'm doing a cam swap in like a month and my 3.42's aren't gonna b enough....
Thats not gonna work unless you remove the entire axle housing to change the pinion gear & bearings. Thats unnecessary work pulling the entire axle & a much easier job to do on a hoist, axle left in the car. I sure wouldnt consider a shop reputable if they dont even have a hoist & only charging you $150? I would seriously go somewhere else, what appears to be a good deal usually ends up not being a good deal at all when its all said & done.
They just want you to remove the differential, thats the carrier with the ring gear on it so they can switch your ring gear for ya. Not hard at all to switch a ring gear, I would not let these clowns touch my car if I were you. From what youve said they dont have a clue.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I dont smoke anything, why would you go through the trouble of pulling your rear end for a shop thats supposed to know what the hell theyre talking about? Theres a much easier way & less work, leave the axle in the car & rebulid it right on the hoist. Most "REAL" shops use them these days. He can do what he wants, but like I said this so called "reputable shop" doesnt seem so "reputable" for how they go about things.
I wouldn't pull my rear end to rebuild it, and I didn't. But when someone ask me to put in gears I give them several prices. Gear install only in the car, and out of the car, and full rebuild in the car and out of the car. Its completely up to them what they choose. Obviously if you bring me the rear the price will be much cheaper, same as the shop the OP was talking about.
Yea I didnttgjnk about that. If it screws up I really wouldn't wanna pull it again. The shop is mainly an engine shop, they build race engines and do machining. So I can understand them not having a lift. Don't need it if all u specialize in is engines. Again thanks for the help. I'll just let my buddy do it and I'll learn something new so I can do it myself next time
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
If you give them those options & they want to do it that way great. The only option the OP was given by this shop was he has to pull it for the work to be done, & IMO thats not the best option. $150 is CHEAP for that job & OP said he wanted a shop to do the work so they will stand behind it BUT if they screw something up he has to pull it back out & take the axle to them. He can do what he wants but I dont recommend having it done this way.
2 different ways of looking at things. I pulled my tranny, carried it out of town, had it built for a very reasonable price, went and picked it back up, and reinstalled it. How much money did I save actually? Don't know and don't really care. I had who I wanted build it, for a better price then the average Joe Blow, and it was convenient for the builder because a bay and lift in his shop wasn't taken up.......On a side note, there becomes a time where you get tired of doing stupid **** like removing brakes, drive-shafts, and wheels and tires. I have no problem using my experience to set-up someone's rear for them for cheap/free, but I don't wanna take off their brakes and tires and ****. If I wanted to do that I would go be a mechanic. I can definitely see where the engine shop is coming from.
If its worth whatever the savings to you to pull the rear end & these guys know what theyre doing & you dont mind pulling it by all means do what you want its your car.
well my buddy did the install for $250. Backlash at .08. its raining out so i cant tell how much of a difference their is, but it wants to get sideways in a hurry 1st-3rd on 315 nt-01s just by pushing the throttle down. before, it would actually do pretty decent in the rain in 2nd and 3rd it wouldnt turn em over unless i slipped the clutch. (very impressed with these tires) from a gradually increase in throttle i can tell it wants to pull though. also it takes off alt easier, not so much riding the clutch..
Replaced my 2.73 with a 3.42 in about 1 hour. Tourque arm, LCA, shocks panhard and brake hose, ABS connector. DS and sway bar brackets from body. Easily done with some experience and a lift and trans jack.
finally got the car out on some dry pavement, and, these tires HOOK. even with 4.10's and my mods, these tires wont turn over at all, but the car feels like a rocket!
im happy with em!! HUGE improvement over the 3.42's, they should come with 4.10's from the factory lol
