Axle question?
Old Dec 20, 2011 | 04:07 PM
Skeet Skeet's Avatar
Default Axle question?
So I have a 99 z28 and I need new axles for it. Mine got messed up from my bearings. I'm going to be replacing the bearings soon soy question is I have a friend with a 94 rear end and I was wondering if his axles would work with my rear. Thanks in advance.
Old Dec 20, 2011 | 05:05 PM
JRENIGAR's Avatar
I think they have a diff # of splines on them, maybe not though...
Old Dec 20, 2011 | 05:24 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
splines(28) are same.
axles for 94 are # 26063146,axles for 99 are # 26059962. Different part # could be for different length ? somebody else will have to post up.
Above numbers are for 3 channel axles as 1994 didn't have a 4 channel option.
Old Dec 20, 2011 | 06:36 PM
Thanks for the help so far guys. What is exactly the difference with 3 channel and 4 channel? The traction control?
Old Dec 20, 2011 | 06:52 PM
3 channel is ABS with the reluctor ring mounted on the carrier.
4 channel is ABS & Traction Control with a reluctor ring mounted on the axle just inside the wheel flange.
Old Dec 23, 2011 | 07:31 PM
Ok thanks guys. Anybody know the lengths if they are different or not
Old Dec 23, 2011 | 11:22 PM
01ssreda4's Avatar
I have swapped around LS and LT axles/posis and never had a problem with anything fitting.
Old Dec 24, 2011 | 12:48 PM
Ok thanks man. I'm gonna see if I can pick them up then. I can get them cheap so it can't hurt to get them I guess
Old Dec 24, 2011 | 10:20 PM
01ssreda4's Avatar
To the window......to the wall.
Sorry had to.
